Ok ive done more research on the proper turbo for a single 383.What ive come up with is a small list of t4 flange turbos. someone said 1.00 A/R compressor size would do well in a 383 with single turbo? well heres a list of some turbos that may work well on a 383. what is you guys 2cents on the best turbo from this list? or if you could post what turbo isnt on this list that i should check into.
T4 GT66
.81 A/R vband flange.
Site claims the turbo has a 4" exhaust outlet.
T4 60-1 borg warner
.60 COLD , .80 HOT , 3" EXHAUST OUTLET
T5 stage 5 compressor wheel
T4 turbo stage 5
.60 compressor wheel
1.05 A/R turbine housing
INDUCER 2.324" / MAJOR 3.00"
T4 super monster setup
60-1 wet floating ball bearings
turbine housing .60
compressor housing a/r 1.15
50mm wastegate
7.8-19psi
also comes with a 50mm bov
Any comments are welcome. good or bad. thanx.
T4 GT66
T4 60-1 borg warner
T4 turbo stage 5
turbine housing .60
50mm wastegate
7.8-19psi
project89
close
none of them
t4 gt66 is actually a t4 50 trim
t4 60-1 borg warner
is also a small t4
t4 stage 3
is the same dam turbo
t4 monster is a 55mm unit
stop looking at ssautochrome turbos, none of them will work in a single setup
t4 60-1 borg warner
is also a small t4
t4 stage 3
project89
close
if ur set on a cheap ebay turbo look at either one of these
http://cgi.ebay.com/ebaymotors/t4-t0...mZ380075469985
or
this one has a 70mm wheel
http://cgi.ebay.com/ebaymotors/T4-T-...6072QQtcZphoto
or u can get this one
copy of a master power gt42
that has a 4inch ex
or
that has a 4inch ex
Im not looking for a cheap ebay turbo.But i dont wanna pay 2k for one turbo....if all these r wrong what is right? what u r saying is going against everything iver heard.....please explain.and some good turbo suggestions would b appreciated.
project89
close
by all means im not saying dont use a cheap ebay turbo, i have run one for 4 years almost on my car..
but ive also done my research and had multiple ebay model turbos in my hands.
so i know what they actually spec out to.
ebay turbos dont match what they call them
i.e the t70's well some are 70mm turbos
but the majority of them are 52-55 mm units which are way to small for a sb 383
i would go with the second turbo i listed above or the gt45 which is a copy of a master power gt42
The description on the second one says it's "Perfect for 4 and 6 cylander applications" What gives? Just trying to learn...
project89
close
its not a matter of learning its a matter of knowing what the true compressor and turbine wheel specs are on the ebay turbos.
So the guy is lying? I dont understand. Not trying to be a smart a**, I can tell you know more about this than I do...
project89
close
the guys on ebay dont know anything about turbos, they buy the stuff form chinia or were ever and just put it up with whatever there told or they see on the turbo
take for instance the t04e 57 trim turbos they are really 48 trim the wheel sizes do not match what they say
a t70 turbo has a 70mm inducer on the compressor wheel, the ebay ones fopr the majority have 55 mm wheels, there are a few diff models named t70
for instance the old xspower super t70 which has a t3 hotside is really a t3/t61 turbo has a 61mm inducer
while others have a t4 hotside with a ptrim wheel and a 69mm wheel, those are copys of master power t70s which spec out the same
u cannot go buy what they tell u in the auctions u just have to know what they are in order to get the proper sized one
Major bummer! I am looking for a turbo and I am just getting more confused!! I am considering giving up as there are not many places that I have found to learn this stuff. Does trim refer to the pitch of the blades? I posted a new thread to try to collect some more info as a lot of people in our club are interested but we all have the same problem: We all dont know jack about turbo's!! Thank you project89!
project89
close
lemme get u some links this will help u understand alil better
http://www.turbobygarrett.com/turbob...o_tech101.html
http://www.turbobygarrett.com/turbob...o_tech102.html
http://www.turbobygarrett.com/turbob...o_tech103.html
Thank you project89! That helped a lot!
from my experience and my current combo do not go smaller than a t-76. I got mine used off theturboforums for 800 bucks and it is a turbonetics ceramic ballbearing that was 2800 new. It had low miles and came with tons of extra pipe and flanges all for 800 so shop around. If you strap a 70 or smaller to that big inch motor your exhaust temps will cook everyting under the hood as I am having problems with it and the bigger one but think my downpipe may be the cause of it. seeing trap speeds over 135 with 10 lbs on my setup now in my heavy fully loaded with a/c still 92 formula. I have pics all over of the car in stages of building it. just search my name and posts i did if you want to see it from nothing to done.
Quote:
Not true. The turbine/fuel/timing has more to do with EGT than compressor size.Originally Posted by lt1z350
from my experience and my current combo do not go smaller than a t-76. I got mine used off theturboforums for 800 bucks and it is a turbonetics ceramic ballbearing that was 2800 new. It had low miles and came with tons of extra pipe and flanges all for 800 so shop around. If you strap a 70 or smaller to that big inch motor your exhaust temps will cook everyting under the hood as I am having problems with it and the bigger one but think my downpipe may be the cause of it. seeing trap speeds over 135 with 10 lbs on my setup now in my heavy fully loaded with a/c still 92 formula. I have pics all over of the car in stages of building it. just search my name and posts i did if you want to see it from nothing to done. Member
you talk about egt I am having problems with mine being terribly high not sure of exac temp but it will glow the whole hot side in one pass. Not sure why though. not to hijack the thread. i do have this listed and sorry guys.
Quote:
What kind of mufflers and pipe are after the turbo? I would get a $5 - $10 air gauge and tap it into the exhaust to check what the back pressure is first. Originally Posted by lt1z350
you talk about egt I am having problems with mine being terribly high not sure of exac temp but it will glow the whole hot side in one pass. Not sure why though. not to hijack the thread. i do have this listed and sorry guys. What is the timing control, mechanical or EFI? Have you verified the timing at 24* if mechanical?
What model WBO2 is reading 11 AFR? Do the plugs match the WBO2 reading?
i have a cheap cherry bomb that is just like the old flowmaster one chamber. only thing i could find at the time so used it. loud and not sure of back pressure. what is a good muffler that will quiet it some and be non restrictive. thinking of a ultra flow bullet. I run a single 3 inch down pipe to that muffler than a dump and thats it for now. it turns out under the pass door. all 3 inch pipe. I use code 59 so it is like factory timing control efi stuff. I have a inovative wide band and the plugs actually look good. no detionation at all but they are red in color from the nos octaine boost i ran in it so hard to read. they are not rich at all but not lean either. maybe that muffler is more restrictive than I thought. will order one tonight if someone says what to get.
Back to turbos for a 383......
if i do decide to go twin which turbos would be best for the price. t70s?
Lots of them depending on the desired engine characteristics. Post the engine combo details and the desired engine characteristics.Originally Posted by GMODUDE
Back to turbos for a 383......if i do decide to go twin which turbos would be best for the price. t70s?
Quote:
Check out the Dynomax website and download their catalog. It lists the muffler flow CFM and approx. HP the muffler can support. Dynomax is one of the few that flow test their mufflers and publish the data. Pick a muffler that supports you desired HP range and sound. More than likely you will end up with an ultra-flow 3.5" unit.Originally Posted by lt1z350
maybe that muffler is more restrictive than I thought. will order one tonight if someone says what to get. Member
Just get a S400 borg warner turbo and be done.
Quote:
That one would work. What flange and A/R turbine did you have in mind?Originally Posted by xfactor200289
project89
close
this guy on ebay always has s400,s and stuff used and takeoffs
just keep checking his ebay store, he had one last night but i dont see it now
http://cgi.ebay.com/ebaymotors/REBUI...mZ330284129717
i will be running a s475 with a 1.10 a/r t-6 flange.
just go s400 with 1.32 a/r t-6 .
check with majestic turbo thay can help you out.
For a Single 383 your gonna want at least around a 76mm. I went with a Garrett TH08A64 (detroit diesels) 74MM T6 with a .96A/R on my 383. I am still in the process of building it (i have a post on CZ28.com under the FI section)
A T6 is hard to fit BUT it does fit in the battery location!
For Single I would say S400 T6 1.32AR
For twins I would go with 2 Master Power T70 with the .61A/R
Here is my build sooo far, just pulling the motor tomorrow for paint, cam and built the hot side.
http://www.camaroz28.com/forums/showthread.php?t=646416
Jay
Jay
jay rich, how much power are you looking to make with that single?
Most of the BBS kits i've seen recommend a 76mm or so single turbo but T-62's i think for twins, somewhat smaller A/R's. .6's i think.
how much bigger is a T6 flange over the T4? I have a T4 header from BBS coming and S400 would be awesome but its T6
Im hoping for around 600RWHP until i upgrade the wheel to a 88MM Originally Posted by Orr89RocZ
jay rich, how much power are you looking to make with that single?Most of the BBS kits i've seen recommend a 76mm or so single turbo but T-62's i think for twins, somewhat smaller A/R's. .6's i think.
The t6 is very large, with my mez. electric pump and having that stupid 3rd gen steering box it pretty much wont fit anywhere without moving the rad forward ALOT, so I am most likly stuck putting it in the battery tray(just fits). Im gonna try mock up once more tomorrow before I yank the motor.
Jay
is there a turbo that is small enough to fit in the bay without having to move the battery?while still big enough to power a 383?
