Lean at Idle
Old Nov 21, 2008 | 12:27 PM
tpimaro's Avatar
Lean at Idle
I have a 92 Camaro with a ZZ4 bottom end, edelbrock aluminum heads, a comp cam, edelbrock TPI manifold and runners, and some other goodies including a Vortech supercharger and some 32 lbs/hr. injectors. The engine runs pretty good at the top end but seems to have a small miss which is more apparent at idle. I recently added an Innovate motorsports AFR gauge and sensor and no matter what I do to the VE, pulse width offset, or flow rate I cannot get it to go rich at idle or with no boost. I was wondering if anybody has ever had any problems with injectors causing this or if there is something else i should be tuning(making adjustments too)?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
