nitrous to stock 350?
Old Nov 25, 2008 | 03:52 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
hey guys and gals, i was wondering if i were to hook up a nitrous system to my stock 350, what shot can i run? i have a 350, 4 bolt main, edelbrock intake, and 600 cfm carb w spacer, headers rebuilt vacuum advance dizzy. i wanna put a cam in to but sdont kno what specs to go with. any help on these would be great.
Old Nov 25, 2008 | 04:58 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: nitrous to stock 350?
100 to 150 max with stock internals
Old Nov 25, 2008 | 05:17 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I ran a 150 shot on my stock interal TPI. Ran great but I got alot of Tirespin. Haha. I think you could get away with it.
Old Nov 25, 2008 | 05:25 PM
jonarotz's Avatar
Car: 91 Z28
150 shot would be perfectly fine. Just make sure you have plently of fuel pump. The size of the shot really isn't the problem, for the most part, it is when people run lean. That is when the damage happens.
Old Nov 25, 2008 | 05:48 PM
Engine: 355
i have the stock motor mount fuel pump. am i gna have to upgrade it to like a 90gph or something like that?
didnt have any problems with it, besides the tirespin? did u solve the tirespin problem? how?
also what kit did you guys use?
Last edited by billybob6110; Nov 25, 2008 at 05:51 PM. Reason: Automerged Doublepost
Old Nov 25, 2008 | 06:41 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Like the rest of them said 150 max. You should have no problem if you follow the directions, the manufacturers purposly give you bigger fuel jets so you dont lean out (atleast NOS does). Ive only had experience with NOS, ive heard they have a very good tech line if you need help. As for the cam theres alot out there, just depends on where you want your power and how driveable you want it to be.
Old Nov 25, 2008 | 07:23 PM
Engine: 355
i want it to be driveable but also have the power. dont want a radical cam just somethin to get me goin....
Old Nov 25, 2008 | 10:31 PM
[quote=billybob6110;3959477]--------
quote]
Actually, I believe it was because I sprayed right off the line with street tires and that was one run and then we got rained out. On the street during some tuning it was running great on the spray.
Old Nov 26, 2008 | 12:01 AM
Engine: 355
[quote=Imthebriman;3959826]
quote]
sweet.. what kind of fuel pump are u running? i cant run the stock one can i?
Old Nov 26, 2008 | 07:39 AM
jonarotz's Avatar
Car: 91 Z28
I think I would upgrade the fuel pump if you are still using the stock one or a stock replacement. I would recommend at least a 90GPH pump. In your case bigger would be better.
Old Nov 26, 2008 | 11:27 AM
Engine: 355
if i upgrade the pump and not having nitous running at the time how do i maintain it from flooding my carb? and if i do a pressure regulator do i gotta adjust it everytime i run nitrous?
Old Nov 26, 2008 | 11:33 AM
DR.'s Avatar
DR.
Get a good fuel regulator.. Quick fuel is my pref... get a gauge on both sides AFTER the regulator and set it to 7 PSI MAX. A carb runs off of 4-7 PSI.
Another thing is if you want a good pump, get a Holley Blue pump and mount it as close to the fuel tank as possible. Dont split the fuel line until its in the engine bay. Mount the pump and regulator as close to a 90* angle as you can (inside the frame works well) or build a bracket out of 4x4 angle.
Old Nov 26, 2008 | 11:55 AM
Engine: 355
so i have to run a fuel pump next to the tank rathetr then gettin a block mount and mounting the regulator by the intake? and just run regulator at 7 psi and that will work with or without nitrous?
Old Nov 26, 2008 | 11:58 AM
DR.'s Avatar
DR.
Its all according to the pump that you get... A Blue pump is a GREAT pusher pump... not so great as a puller (mounting it far away from the tank). But for a Blue, yes mount it close to the tank.
As far as the 7 PSI, yes it will work either way.
Old Nov 26, 2008 | 12:06 PM
Engine: 355
i was looking at either the edelbrock or the holley block mounted pump. 90gph
http://store.summitracing.com/partde...5&autoview=sku. think itll work?
wrong size but u get idea
Old Nov 26, 2008 | 12:16 PM
Engine: 355
also i get a wet kit right?
Old Nov 26, 2008 | 12:52 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
yes get a wet kit. retard timing 4 degrees ona 150 kit.
Do not go any higher than 150 unless ur cool about possibly blowing it up. you piston rings arent set from gm to handle a huge shot.
launch on motor then grab the kit in second if auto.
holley blue pump is good for 550fwhp so thats a good one. thats what i have. i also have a dedicated fuel system but you dnt need that.
cam wise get a nitrous cam if you really want to use nitrous and ll. itll be a big increase on motor and even bigger on spray.
if you just want a regular cam thats good for motor and al, get one with a higher lsa not some radical idle its bad on spray
Old Nov 26, 2008 | 01:00 PM
DR.'s Avatar
DR.
agreed w/ kowboy
If your going to use the giggle button alot, get a nitrous cam. If not, get a nice street cam... you'll be happy either way I think.
Just to be safe, I dont run over a 125 shot on a stock motor. but thats just me...
DR
Old Nov 26, 2008 | 01:36 PM
Engine: 355
ya im not gna use the bottle alot. jus something if i need that "i wanna goooooo". but i really wanna just do 100 shot to be safe. im just kinda worried on my fuel supply. i wanna do the mechanical and a regulator but im not sure if itll handle it
and cam wise i dont wanna radical cam just a nice street cam.
Last edited by billybob6110; Nov 26, 2008 at 01:37 PM. Reason: Automerged Doublepost
Old Nov 26, 2008 | 01:54 PM
DR.'s Avatar
DR.
A mechanical pump would not be a wise choice in my opinion. Its not very expencive for an electric pump, and its alot more reliable as far as longevity. A mechanical pump is good for a stock motor, not for one w/ go-go juice.
Old Nov 26, 2008 | 03:56 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ya then you will be fine with it on spray.
125 shot imo.
its like a 100 to the wheels.
ummm get a holley blue top and call it a day. mount it under the back driver side passenger area. thats where mine is. like where the fue filter goes
Old Nov 26, 2008 | 05:54 PM
Engine: 355
125 shot imo.
thanks for the help guys... how difficult is it to run a pump from the rear tank? would i eliminate the mechanical pump altogether? and i have a fuel gaue on there now, do i just put the regulator inline right before the gauge and fuel filter? also do i just put the pump in the existing line from the tank to the regulator/carb?
125 shot imo.
got any pics?
Last edited by billybob6110; Nov 26, 2008 at 05:58 PM. Reason: Automerged Doublepost
Old Nov 26, 2008 | 06:18 PM
I ran the stock fuel pump on mine for the time that I had the nitrous on the car. I would recomend upgrading however I had no problems with using the stock one.
Old Nov 26, 2008 | 06:34 PM
Engine: 355
really? i wanna do that but maybe upgrade the mechanical for now and do electric when i kno nitrous is what i want.... u run a regulator or just stock pump only?
Old Nov 26, 2008 | 08:26 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Yes eliminate the mechanincal all together, run the electric as close to the tank as you can befor the filter. You will need a regulator, alot of times they come with a gauge port so you can tap in at the regulator. You wouldn't need a gauge befor and after the regulator cause all you care about is the psi going into the carb and if you lose fuel pressure you'll know either way. Only reason briman was able to use his stocker is because his engine is FI and came stock with a electric pump. System wise all plate systems are wet, if you wanna get wild you could get a fogger kit. In school we got 490hp out of a 350 using the fogger kit with stock rotating assembly, mild cam, aluminum heads, and msd. About 340 with the plate. Engine baselined at around 250 er so.
Old Nov 26, 2008 | 08:43 PM
Engine: 355
what happens if i use the stock pump? will it not work properly or is it just that everybody likes the electric type?+
and with reguators do i need them an fittings or do they make em to use normal lines in it?
Last edited by billybob6110; Nov 26, 2008 at 08:44 PM. Reason: Automerged Doublepost
Old Nov 26, 2008 | 09:53 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
http://www.jegs.com/p/JEGS/773419/10002/-1
Example of one here from jegs. Has 3/8 inlet and outlet with a 1/8 gauge port so you dont have to mess with any an fittings. The mechanical pump should work only reason id go with electric is if i decided to go with a different setup like fuel injected. It would work either way as long as you get enough fuel and dont lean out.
Old Nov 26, 2008 | 11:51 PM
Engine: 355
im thinking i wont change to fuel injection, so w that regulator it already comes with the pieces to go in the hose to connect it?
Old Nov 27, 2008 | 11:21 AM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
it sounds like it only comes with the regulator and a mounting bracket. If you call jegs up they're really helpful on getting you what you need for the project. If you go with a regular rubber fuel hose you can just get a barbed fitting with a 3/8 thred on the other end, clamp it on and you're good to go.
Old Dec 1, 2008 | 01:36 PM
Engine: 355
ok guys i called to get a 110gph mech pump and the pump only has two ports. one in and to carb. how do i run the vent line (i think thats what it is) to make the pump work. the part number is sum-2500201 on summitracing.com. thanks guys i wanna get it hooked up and running ur help is appreciated
Old Dec 1, 2008 | 07:48 PM
Engine: 355
anybody?
Old Dec 3, 2008 | 07:43 PM
Engine: 355
im gna go with the carter pump since it has all the hookups to leave stock fuel setup alone. i was getting told that i dont need a regulatro and that the pump (pushes only 6.5psi) would be enough for 100 shot. is that correct? i dont wanna blow my motor up
Old Dec 3, 2008 | 08:13 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
does t have a return system? if you do i dont think it will work. my carter runs on a non return setup. that carter i hav is set for my stand alone fuel system for the spray
Old Dec 3, 2008 | 10:03 PM
Engine: 355
ya itll have a return system. so what pump should i run? i want a mechanical pump so thatd be better
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
