i need a timing retard
Old Jan 18, 2009 | 08:28 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i need something that will kick in and retard timing for when i hit the nitrous.
i mostly run my car on motor so having this thing retarded in timing sucks.
I know the digital 6 ignition box has a one step timing retard but i dont need a whole ignition box
Old Jan 18, 2009 | 10:31 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: i need a timing retard
Well you have two options. Digital six or a flip chip. I have the digital six and it works flawlessly. I have it wired into my arming switch. As soo as the switch is on I pull three degrees of timing. Craig Moates has a chip with a switch that can change tunes. So you could have a nitrous tune with less timing. But the Digital six is the mose cost effective. Do you have an MSD box? You can buy just a retard box to work with a 6AL. I was going to do that but instead sold it and got the digital six. Hope that helps.
Old Jan 21, 2009 | 11:38 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
i got a full msn system but i cant figure out how to wire up my window retard box . you have any clue how to do it?
Old Jan 22, 2009 | 01:38 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
all msd wiring diagrams are on their website under each individual part.
Old Jan 23, 2009 | 11:38 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Dude check out the Mallory 685 its got a window switch and high speed retard. Easy to set with the simple digital interface. I'm using it for the boost retard and rev limiter, but its for any and all power adders.
Old Jan 26, 2009 | 12:37 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
i run the msd 3 step tard box with msd 6a. the retard pills are activated from being removed from ground, so wire it to the positive side of your n20 solinoids. it will be grounded until power is supplied.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
