Blow off valve issues?
Old Mar 18, 2009 | 07:50 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
Im runnin a 305 tpi with mods and a paxton supercharger, i have a ssq blow valve but it never blows off when you let off the throttle its not seeing vacumn has anyone had this problem or know how to fix the issue. At idle i barley see any vacumn cause of the charger.I have tried a turbo style valve had the same issue i was told go with the ssq valve caue its supposed to open when it sees any fluxuation but still no good.
Old Mar 20, 2009 | 09:42 AM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Re: Blow off valve issues?
Did you hook the blow off valve vacuum port to a location on your intake with a good vacuum signal? Anywhere on the intake after the throttle body should work. I know on my tial blow off valve I had to put a different spring in it to get it to work properly. If it is hooked up properly I'd look into putting a softer spring in it.
Old Mar 20, 2009 | 06:58 PM
Car: 86 Iroc-z
I have the vac line hooked up to the throttle body vac source i thought that was ok but ill try a diff spot. My blow off valve is a sequential supposively no spring just an internal diapram and is supposed to open with any fluxation of the throttle but its not. I have tried turbo blow offs and put a lighter spring still nothing its just not seeing vac
Old Mar 20, 2009 | 07:34 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
could the diaphram be ripped internally? and your not seeing any vacuum
Old Mar 20, 2009 | 09:41 PM
Car: 86 Iroc-z
well the valve is new just installed it so it should be good, gonna try putting a vacuum gauge on the vac line for the valve and see what it reads tomorrow.
Ghettobird52
Jul 5, 2024 11:18 PM
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
