can i put a weiand supercharger or no?
Old May 5, 2009 | 11:40 PM
91camaroplaya's Avatar
Car: 1991 camaro
Engine: 355
Transmission: 700r4 w/shift kit and b&m megashift
i have a 1991 camaro...
bottom end is .40 over
roller cam .502 lift
heads are pretty much stock
compression is 10.1
edelbrock performer intake
msd streetfire ignition
holley 600cfm carb
i have 425hp.... my buddy just did more **** to his stupid trailblazer ss and now i need more power...
could i supercharge the motor the way it is?
if not what do you suggest for me to get more power easily...
Old May 5, 2009 | 11:48 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: can i put a weiand supercharger or no?
10:1, iorn heads NA,is not a good combo for boost. mabie 4-5 psi
Old May 6, 2009 | 11:25 PM
Car: 1991 camaro
Engine: 355
well i do know that the heads had a three angle valve job when i had the motor done a year ago...
also the motor is a vortec motor idk how it ended up in my car but i bought it with that in it lol
if you still say no to the supercharger... any ideas on another big power adder?
Old May 6, 2009 | 11:31 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
You can supercharge it just fine, the problem is you final compression ratio. If you have aluminum heads you have a little room, with cast iron you are already at the upper limit. Much higher and you will need race gas, or to retard timing so much there is no point. You can pull the motor, and put in pistons with a dish, or get new heads with a bigger cc. Have you thought about No2?
Old May 7, 2009 | 12:55 PM
Wrenchp's Avatar
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
N2O is the cheapest solution here that is for sure.
My buddy put 10 pounds from a turbo on his 10.5 to 1 compression LT1. But that is with reverse flow cooling and stock Al heads. He didn't hurt anything except a head gasket once.
I would say if you are really stuck on a SC then consider race gas or a meth kit and run 10 lbs on it. It would considerably increase power but then you run into more $ for fuel or having to make sure there is window washer fluid in the Meth tank.
Boost is an addiction so you will want to open your motor later and go less compression and up the boost.
Old May 14, 2009 | 10:30 PM
Car: 1991 camaro
Engine: 355
okay thanks for the tips guys.. i thinkthat my best bet and cheapest solution is to go with the nitrous system in the car. iim gonna be looking into that more for now. thanks to all.
Old May 14, 2009 | 10:41 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
when i was a kid there was a speed shop i used to go to and there was a sign on the wall - i still remember it, something about the two rules of racing.
rule 1
"speed costs - how fast can you afford to to."
rule 2
"there is no substitute for cubic inches."
the cam is a little small - even a zz4 will give you .474/.510 lift on 1.5 rockers.
get new heads
give yourself some room with the heads - and put that supercharger on - blow the doors off that truck.
and a 383 would be nice but not as nice as a 502 but that would be a bbc instead of a sbc.
AussiePr0nCar
Mar 6, 2020 04:04 PM
toronto formula
Nov 10, 2015 06:17 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
