Weiand Roots
Old Jun 16, 2009 | 06:15 PM
lanmankilla's Avatar
Car: 84 Z28
Engine: LG4
Weiand Roots
Has anyone used a weiand roots blower, such as the 142 or 144 on the LG4? It said it could add 100 some hp on a 350 so I take it, obviously less on a 305. I figured it would be something that added power until I swap a bigger engine that I could transfer it to as well.
Old Jun 16, 2009 | 07:47 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Re: Weiand Roots
I don't believe it clears the stock hood... not to mention if your motor is still pretty stock including the carburetor and what not, your pretty limited to the amount of stuff you can do with the supercharger
correct me if im wrong anyone but even if you use a low profile air cleaner, doesn't it still not fit??
Old Jun 16, 2009 | 10:13 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Weiand Roots
It is pretty much linear in terms of HP increase. If it makes 100 HP on a 350ci then using a similar built 305ci it will make (305/350)*100 = 87 HP.
I would guess that the 100HP is predicted for a 350ci making about 200HP stock and the S/C pushes about 8 PSI through it.
Old Jun 17, 2009 | 04:18 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Weiand Roots
Not positive about the Weiand blower, but I'm using an Edelbrock E-Force blower which is close to the same dimensions and you'll need a 4" cowl hood and a low profile air cleaner to fit everything. -Or you can just get a 6-71 blower and cut a hole!
I've heard of power increase estimates in HP and percentage both. Most small blowers are capable of a 30-50% HP increase, but it all depends on how the engine is set up to handle the boost really.
JSDaddy189
Sep 26, 2015 03:50 PM
dimented24x7
Sep 17, 2015 06:58 AM
TexasMaro
Sep 15, 2015 06:50 PM
R3500
Sep 8, 2015 10:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
