91 Z 6.0 turbo project finally finished
Old Jul 5, 2009 | 07:17 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Here are a few pics of the 6.0 swap I just finished with a single turbo.
Old Jul 5, 2009 | 07:18 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Re: 91 Z 6.0 turbo project finally finished
Old Jul 5, 2009 | 07:38 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That looks Effin SICK! Props. Looks immaculate, Color choice is perfect too. Well done!
Old Jul 5, 2009 | 08:18 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Very nice! Almost looks like it could be stock! (That is, if GM ever put a turbocharged LS in a Thirdgen!) Where did you mount your coolant bottle?
Old Jul 5, 2009 | 08:36 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
I mounted a bottle under the filler panel in the front by the hood latch.
Old Jul 5, 2009 | 09:58 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
very nice, mad props for that!
Old Jul 6, 2009 | 12:09 AM
IROCFAST's Avatar
That is awesome man!
Old Jul 6, 2009 | 12:25 AM
IrocZTPI's Avatar
Car: 1990 Camaro Iroc Z
Engine: 5.7L TPI
thats sick i am thinking about doing a LS7 swap in mine
Old Jul 6, 2009 | 02:06 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
yea good luck on that... thats about a 30,000$ or more motor
Old Jul 6, 2009 | 02:14 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
damn dude...
Old Jul 6, 2009 | 02:23 AM
Irocz28NCHS's Avatar
Car: 1986 Irocz28
Engine: 305 tpi
Axle/Gears: stock
wow looks very sick i wanna do this when i swap mine next summer.
Old Jul 6, 2009 | 05:02 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Very clean setup. Props. Any HP numbers or track times?
Old Jul 6, 2009 | 07:10 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Have you had it dynoed?
Eric
Old Jul 6, 2009 | 09:24 PM
blinkn's Avatar
Car: 1991 Firebird Formula
SICK! what did you do in regards to engine management? ecm?
Old Jul 6, 2009 | 09:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Wow thats the way i should have gone but oh well.
Very nicely done and very nice car. Dont see many black with red stripes like that
Old Jul 6, 2009 | 10:04 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
absoutely beautiful, very clean.
thats very similar to how i mounted my tc-78 in my 91. that was on a gen 1 355 tho, now i am starting an LQ4 build myself.
id be very interested in any build pics youd like to share,
especially hotside pics.
thanks very much!
you can pm me if you want
nice job!
Old Jul 7, 2009 | 01:29 AM
Dont go LS-7, get a 6.0 truck block and get an eagle forged assembly and RHS or trick-flow heads. Mine is 425 ci and makes just as much power as the LS-7 (Only cost me around $14,000 too!)
82z28man; Just beautiful!! Gotta love a black thirdgen, especially when it's as clean as yours!
Old Jul 7, 2009 | 06:39 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Nice clean install! Looks like it belongs there!!
Old Jul 7, 2009 | 06:55 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Not yet but very soon, i've only got the wastegate set to about 6 lbs right now and it pulls very hard, i plan to make about 10 so i cant wait to see how it feels then.
Its an 01 PCM that I tune with HP tuners.
thanks very much!
nice job![/QUOTE] This is my build thread if you wanna check it out. https://www.thirdgen.org/forums/ltx-...1-z-6-0-a.html
Old Jul 7, 2009 | 07:48 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
Extremely nice job !! Mad props !! However, I seemed to have noticed in your sig, it says LT1.... that doesn't look like an LT1 ?? Or is it ??
Old Jul 7, 2009 | 10:48 PM
SilentBobZ28's Avatar
Car: 2014 2SS/RS
Engine: LS3
Transmission: TR6060
Axle/Gears: 3.55
That is one heck of a wolf in third gen clothing. Have fun smearing the track with mustangs and 4th gen's.
Old Aug 22, 2009 | 06:01 PM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
currently redoing mine for a similair setup. Do you have some more pics of your setup? It would help me in decideing were to put my turbo. Thanks
Old Aug 31, 2009 | 02:48 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
Which manifolds did you use? I have some truck manifolds but I don't believe they will work on the 3rd gen. Do you have a build thread? I am doing a 89RS as we speak.
Old Sep 26, 2009 | 10:07 PM
blinkn's Avatar
still waiting on those hp numbers lol!
Old Sep 27, 2009 | 10:14 AM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Good timing because i just put it on the dyno yesterday. A little dissapointed in the hp, 512 hp and 573tq at the wheels. I need to add some timing on the top end and the hp should get up there, i just didnt have time to change it and log it to make sure there was no knock. heres a video of the run.
http://vids.myspace.com/index.cfm?fu...deoID=63562643
Old Sep 27, 2009 | 02:51 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Very nice....!
Old Sep 29, 2009 | 11:43 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
How quick does that turbo spool up? What cam?
Old Sep 29, 2009 | 12:10 PM
Car: 91 camaro rs
NASTY!!!
Old Jan 8, 2013 | 05:17 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
about to start on mine now using a 6.0 block L92 heads and holley 102mm Hi ram intake with LS9 internals (cam gaskets) what did you do to the 4l80e because ill be using the same trans and what stall did you go with.
Old Jan 12, 2013 | 10:27 AM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Its a ck performance level 2 with a trans brake. Still completely controlled by the pcm. The converter is a precision 3200 with a 3 disk lock up.
Old Jan 15, 2013 | 08:19 PM
The_F_body_kid's Avatar
Car: 85 z28
Engine: 410 CI
Transmission: 700 r4
Axle/Gears: 373
very well done indeed
Old Feb 1, 2013 | 11:41 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
This turbo mounting looks very well done!
Do you happen to have more detailed photos of the exhaust crossover?
Old Feb 1, 2013 | 11:50 AM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
This is actually a build thread from when I first built the car. Ive done alot of changes to it since then. Heres my latest build thread from a couple years ago. Theres alot more detailed pics of the turbo set up. http://ls1tech.com/forums/forced-ind...80e-build.html
Old Feb 2, 2013 | 08:09 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
Awsome setup! I saw pics of the manifolds on your ls1tech thread. What kind of manifolds are they, is the passenger side custom or is it sold somewhere? Do you have a video anywhere online? I followed the myspace link but there is no longer a video posted. I would love to hear it with the 4" magnaflow, I have the same exhaust on my NA 383 and I'm looking to go turbo LS.
Old Feb 2, 2013 | 09:32 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Thank you, The driver side is a factory manifold I spent alot of time on cleaning up and the passenger side is one that I built. heres a video of the car, not really the best for sound but it might give you and idea of what it sounds like.
Old Feb 2, 2013 | 09:41 PM
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
Wow! What a fkn win! Makes the fire burn when I see a thirdgen take off like that from a dig...
Old Feb 2, 2013 | 10:24 PM
SMKNGTA's Avatar
Car: 1989 GTA
Thanks for the quick reply. Way to walk all over that Z06...
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Polo Z03
Sep 10, 2015 06:43 PM
