Post pics of your turbo set up
Old Jan 19, 2012 | 03:13 PM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
I'd like to see some pics of the turbo set ups out there front mount or rear mount single or twins post them up. Trying to decide what I wanna do
Old Jan 19, 2012 | 03:19 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Post pics of your turbo set up
I'm not usually one to say search, but... use the search button
and oh yeah, this is a sticky...
https://www.thirdgen.org/forums/powe...pics-your.html
Old Jan 19, 2012 | 07:58 PM
project89's Avatar
Old Jan 20, 2012 | 10:13 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Originally Posted by project89
Im jelous!
Old Jan 20, 2012 | 10:23 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by fasteddi
Im jelous!
Don't be... your car is faster lol.
Old Jan 20, 2012 | 07:13 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I wish!! I need alot more $$ to get my car to be anywhere near as fast as that car. If i can keep up with stock 350 tpi's in a few months Ill be happy!!!!
Old Jan 23, 2012 | 04:21 PM
lilpiston8's Avatar
Car: 85 iroc
Engine: 388 procharged
Transmission: 4l80
Axle/Gears: moser 9 inch / 3.40 gear
here is what I run
Old Jan 23, 2012 | 07:35 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
^ alcohol, lots of meth, or lots of *****?
NICE!
Old Jan 23, 2012 | 08:42 PM
fasteddi's Avatar
Car: 1991 Camaro RS
NICE!
Nice, no In.Cooler??? I love that turbonetrics!!
Old Jan 23, 2012 | 10:36 PM
lilpiston8's Avatar
Car: 85 iroc
Transmission: 4l80
Yeah I run e85. with a healthy dose of meth injection.
Old Jan 23, 2012 | 10:59 PM
lilpiston8's Avatar
Car: 85 iroc
Transmission: 4l80
another shot of the beast.
Old Jan 23, 2012 | 11:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You can get away with alot on corn and meth
Old Jan 24, 2012 | 05:00 PM
daverr's Avatar
here is my remote front mount turbo setup so far.......
File Type: jpg
Old Jan 24, 2012 | 05:28 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Wow man thats a big BIG turbo. Looks sweet!!! That turbos about the size of my motor
Old Jan 25, 2012 | 08:16 AM
VORTECCADDY's Avatar
Engine: 383 Superchared
Transmission: 700r4 built
Sick!!
Old Jan 26, 2012 | 02:38 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I'm always down for a little pic whoring. Heres a few shots of mine...not done yet, but almost there.
Old Jan 26, 2012 | 04:54 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Too bad I managed to bend and crack the frame...
Old Jan 30, 2012 | 06:57 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
thad bites so ur set up for sale lol
Old Jan 30, 2012 | 07:03 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
how did you crack the frame on a unibody car?
Old Jan 30, 2012 | 08:38 PM
Car: 91 Formula
Large bend and crack just forward of motor mounts. Looked like a previous repair came undone. Car was totaled and rebuilt very early in its life before I got it, lol pre-carfax. Went to do some WOT tuning one night, all seemed normal. Next day car was leaning hard right, found damage. I'm sure it was a slow progressive thing that finally gave because it always tracked dead straight never an alignment problem, surely 12lbs boost only accelerated what was already failing.
And no, setup is not for sale. Its getting swapped into a 91 Vert
Old Feb 1, 2012 | 09:43 PM
black1990RS's Avatar
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
what size turbo? do you have any other pics you could show of how the turbo sits in the battery tray
Old Feb 2, 2012 | 12:49 AM
Car: 91 Formula
FSTFBDY Fabbed most of it up. I had to tweak a few things to make the downpipe fit and in the process lost the AC, gonna make a few adjustments and see if I can squeeze AC back in by losing the serpentine setup when I swap into the vert. Turbo is a MP T70, only downfall to to the location is air filter space. Otherwise very easy to work on.
Old Feb 2, 2012 | 07:54 PM
Car: 1990 camaro RS
how do you have that driver side exhuast ran? is it right under the front of the oil pan?
Old Feb 4, 2012 | 10:48 AM
Car: 91 Formula
snakes around under the balancer, plenty of room and leaves clearance to work on things.
Old Feb 4, 2012 | 11:13 AM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
I like this set up nice clean and not Clattered with piping
Old Feb 4, 2012 | 12:02 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Heres mine so far. This is a budget build but I think its coming out ok..
Old Feb 13, 2012 | 11:16 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
When i saw this setup on FSTFBDY's car i had to do it the same way or atleast close. If you wouldnt mind, could you post some pic's of under the car where the pipe runs? I want to see how it was put together down there. I will say, a very clean put togther system, if you wouldnt mind me asking, how much did you buy it for? I know its all stainless steel piping, etc.
Old Feb 13, 2012 | 11:53 PM
Car: 91 Formula
I'll have to dig through my pics and see if I have anything from the underside, not sure what I have. Meant to start a build thread for the turbo setup but was kinda busy with a divorce lol. Now that I have garage space again I'll probably do a un-build thread when I finally swap it into the vert.
Can't really price it out at this point, we traded straight up my supercharger setup for the turbo setup
Old Feb 14, 2012 | 12:04 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Please post the thread when you do so, im sure not only me is interested. Great job!
Old Feb 14, 2012 | 05:57 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Im done with my turbo set up, just tuning now.
Old Feb 17, 2012 | 01:19 AM
Slayerx666's Avatar
Ugh I wish I knew how to build a turbo set up...
Old Feb 17, 2012 | 03:04 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
You and me bith man. I just dont have the patience for it either. Rather buy built setup for the car at this point in time
Old Feb 17, 2012 | 08:11 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Just takes creativity, a good welder, and time.
Tuning the ECU is the hard part!
Old Feb 17, 2012 | 10:19 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
I could build a turbo set up if i had everything but have no clue on the tuning the ECU part like fasteddi.
Old Feb 18, 2012 | 12:53 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You guys underestimate yourself. A few good books and a budget welder will allow you to make your own kit. Just need some common sense and some basic craft skills to pull it off
Old Feb 18, 2012 | 07:27 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Your definitly right as I never though Id be able to make a turbo setup and it works But now ive got it up and running and the tuning is under way. Slow process but it IS working the way I thought it would. And my build came in under 800 bucks. So it all about what you can fab up yourself, and how much creativity you have. Its a learning process thats forsure.
Old Feb 18, 2012 | 07:45 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thats gonna be one sick vert ! we need to meet up some day. Vert vs vert for some good ol fun. ( and you know IVE GOT 1ST DIBBS ON MY OLD SETUP BACK IF YOU DO GET RID OF IT)
For those looking for a few more pic's of it. Here. http://www.cecoatings.com/images/Car.../hotside304ss/
Old Feb 18, 2012 | 03:01 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
what u all think
Attached Thumbnails Post pics of your turbo set up-232.jpg   Post pics of your turbo set up-279.jpg
Old Feb 19, 2012 | 10:19 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
That gives a great view of the setup. Few questions on the piping, turbo mounting, and the oil return line. If you ever have to remove the setup for what ever reason, how would you get it off? Is there like a clamp half way dividing the system? Also for the mounting of the turbo, is the turbo sitting up into the air or is it resting on the passenger side battery pan? And do you have any pictures on how the oil return line is ran?
Old Feb 20, 2012 | 10:41 AM
Car: 91 Formula
If I ever get rid of it, it'll be replaced with twins and you'll have first dibs Chris
The pipes separate in the middle under the balancer, and the downpipe separates just before it turns down. The turbo is basically braced by the cold side piping. Goes through a hole in the battery tray and the pipe is supported by a bracket. The whole system comes apart remarkably easy. The 2 downsides is the oil drain and the air filter. The oil drains into a -10AN hose direct to a 90deg fitting, far from ideal, in to the fuel pump blockoff plate. I do run a restrictor on the oil feed though and have had no signs of the oil backing up at all. The air filter is simply a nightmare lol. Almost have to pull the fender to get it in, that will definitely be tweaked before it gets swapped in.
Old Feb 20, 2012 | 10:57 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That would be my concern with that setup. Oil draining. My turbos are now in similar location and I will be running a scavenge pump....i just dont see a way to drain them, especially the driver side.
Old Feb 23, 2012 | 01:07 AM
  #42
camaro1122's Avatar
Engine: 5.0 LB9 TPI
For your oil return, do you have a high volume oil pump? Im considering on running mine to the block off plate as well, but since i have a high volume pump im not sure it will work.
Old Feb 25, 2012 | 08:03 AM
  #43
fasteddi's Avatar
Car: 1991 Camaro RS
Painted the charge pipe, and added a (ok air filter set up for now) I'm very happy with what it looks and runs like for now. Not bad for making this build go from parts to running in a little under 2 months?? And its my first attempt at turboing any car.
What you guys think??
Old Feb 25, 2012 | 10:07 PM
  #44
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
its pretty nice!
Old Feb 26, 2012 | 02:19 PM
  #45
fasteddi's Avatar
Car: 1991 Camaro RS
its pretty nice!
Old Oct 5, 2012 | 06:24 PM
  #46
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Nice setup guys. I sold my supercharger and will soon have another turbo setup under the hood of my vert.
Old Oct 6, 2012 | 07:21 AM
  #47
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
good to hear man....ive been re-designing my hot side....almost finished
Old Oct 6, 2012 | 09:17 AM
  #48
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
sweet. You will deff. be glad ya keep it once the bugs are worked out. I liked the Novi buy wish I would have keep my old turbo setup.
Old Oct 13, 2012 | 08:04 PM
  #49
heres my re designed setup that im almost finished with
Attached Thumbnails Post pics of your turbo set up-new-downpipe-3.jpg   Post pics of your turbo set up-finished-downpipe.jpg
Old Oct 14, 2012 | 08:22 PM
  #50
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
In the middle of my build...
Attached Thumbnails Post pics of your turbo set up-car-015.jpg   Post pics of your turbo set up-car-019.jpg
