T brake n20 wiring
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
T brake n20 wiring
does anybody have a diagram for interupting the n20 while trans brake is engaged? i saw it on yellow bullet a few months back, but cant seem to find it anywhere now.
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: T brake n20 wiring
i would think using the NC contacts on a small relay would work pretty well for that.. maintaining the connection unless the trans brake is triggered operating the relay and breaking the n20 activation circuit until the brake is released.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
here`s two simple ones, if you need other things like digi sets or rpm switches..I have more!
thats the one, thanks greeze!
did your engine not like the 8's club?
1992 Trans Am
May 10, 2023 07:19 PM
I was pushing that combo pretty hard, the new engine should be alot more efficient on the sauce
