TBI N20
Old Aug 5, 2009 | 01:00 PM
Camarokid08731's Avatar
TBI N20
ok so i have experience putting spray on my 99 ls1 z28 but now i wana spray my third gen. Its a 91 tbi whats the best route to take fogger? plate? how do i increase fuel? etc
Old Aug 5, 2009 | 01:30 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: TBI N20
There are plate setups, check jegs or summit. About 400 bucks without the bottle. Stock fuel pump might not cut it.
Old Aug 5, 2009 | 04:14 PM
Zero4488's Avatar
Re: TBI N20
has anyone shot a tbi car yet? what can these hold lookin to do like a 75 or 50 shot wet or dry...
this is the original poster typing on my buddys acount
Old Aug 5, 2009 | 04:48 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Re: TBI N20
You need one of these:
NOS part number for the kit is 05153. You should be able to get it from Jegs, Summit, or any place that sells NOS brand products. This is a wet kit.
The kit will come with jets and directions that will recommend what size shot to run.
Old Aug 6, 2009 | 09:37 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: TBI N20
A lot of people have sprayed TBI motors, I think the general concensus is that 150 is safe, but I would do some research on what the fuel pump can support, I forget. Not enough fuel and I can guarantee you your engine will melt.
Old Aug 6, 2009 | 11:15 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: TBI N20
150 Shot TBI vs 01 Lightning and BPU 02 Z28
http://www.youtube.com/watch?v=KfbJFGcx0SY
I plan to shoot my TBI with a 100 shot. I'm looking to get about 300/300 out of this motor and 400/400 on spray. In due time...
Old Aug 7, 2009 | 11:55 PM
Re: TBI N20
how exactly will the car see the nitrous added to it...it runs on a speed density tune correct? am i going to have to depend on a narrow band 02 sensor (if i do a dry shot) and if i do a wet shot weres the best place to introduce the n20/gasoline before the injectors kinda like how a carb setup is that has a plate kit or putting a fogger on top of the tb
Old Aug 8, 2009 | 01:33 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Re: TBI N20
Could we do something like so?
Old Aug 10, 2009 | 03:29 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: TBI N20
i wouldnt i believe thats designed to shoot into all 4 barrels of a 4150 carb, which wouldn't work well at all with TBI. your best option is to run a plate, or do a dry direct port and custom tune for the nitrous with bigger injectors. thats a lot more complicated tho, i'd just put a plate on it and do it that way
Old Aug 13, 2009 | 06:40 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: TBI N20
I'd recommend a wet kit, probably going to be the easiest route. The TBI is a wet manifold, designed to flow fuel through it, so you don't have to worry so much about fuel puddling in the intake. I have done both wet and try kits and I personally feel wet kits are safer and make more power.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
