Mass air problem with charger, help please
Old Aug 9, 2009 | 05:26 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
I have an 86 iroc tpi runnin a paxton charger, I have the mass air flow mounted on the charge side of the charger and also runnin stock ecu which i know is the issue i know i need a custom chip done,The problem is the stock ecu is calibrated at idle or under 10 percent throttle its supposed to see between 5 and 7 grams of air per sec but at idle with the charger its at 9 to 10 grams per second which is kickin the check engine light for high mass air and 42 cause its tryin to retard the timing seein too much air. I have already tried mounting the mass air on the inlet side of charger and it runs fine no codes but not efficient not being on the boost side.Has any one had this issue or know how to get around it besides a custom chip with new calibrations eventually i know i have to but i dont have the 600 for the chip from tpis right now.any help would be appreciated thanks
Old Aug 9, 2009 | 09:54 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Mass air problem with charger, help please
i had that same problem i have a paxton on my 1988 tpi 355 motor,i used to run mass airflow on the boost side i was always getting mass airflow high voltage when it was cold outside.i adjusted the tps from stock .54 to .64 and the light never came back on.but now i moved it to the sucking side after the air filter but it was running ok with a stock chip but now i have a custom made on.
Old Aug 10, 2009 | 06:13 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i have the same setup on my car except its a 350 and have the stock comp in it and i have no codes
Old Aug 10, 2009 | 06:39 AM
tom86iroc's Avatar
Car: 1986 iroc
Size:  127.5 KB Name:  DSC00196.jpg
Old Aug 10, 2009 | 08:36 PM
Car: 86 Iroc-z
Thanks for everyones help, im gonna try puttin the mass air on the inlet side of charger for now and make sure no codes come back as it was when i first installed it to rule out that there is nothong else wrong besides the mass air seeing too much air snd go from there.Also thanks for the diagrams thats a big help so i can trace things if need be, its a big help
Old Aug 16, 2009 | 11:26 AM
Car: 86 Iroc-z
Well still having the hi mass air flow code but it takes a few miles for it to come on i had set the tps sensor to .64 volts and i noticed a big diff i had a weak spot in the rpm range between 2000 and 3000 that it took care of so thanks for the tip def helped.I put thr mass air sensor on the inlet side now it just takes longer for the code to show up is there any more suggestions on how to fix or get around this issue? Tpis sais they can do a custom chip and can fix the issue just wondering if there is something i can try myself for now any ideas?It runs better than it ever has now just the code issue
Old Aug 16, 2009 | 11:42 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Anyone can do the chip. Just the airflow value for tripping the code needs to be changed. For such a simple change I bet TPIS gets a big chunk of change.
Old Aug 16, 2009 | 01:18 PM
Car: 86 Iroc-z
tpis suggests the stage 5 chip cause its supercharged and with all the other mods they want round 600 to burn a custom chip but they say it will gain alot more horse too im sure its worth it but for changing one value for the mass air to get it to run right thats alot of money for now
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
