supercharger help
Old Aug 17, 2009 | 02:08 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
supercharger help
I want to replace my 305 tbi with a supercharged 350 and i don't not know what supercharger to get and if i can use my same throttle body?
Old Aug 17, 2009 | 09:38 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: supercharger help
Prochargers are really good, and I believe they make a kit for a TBI.
Old Aug 18, 2009 | 06:13 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I think a TBI could even be bolted on a roots type supercharger. The real question with a TBI is how to supply enough fuel. Even the big 454 injectors will have trouble feeding a blown 350.
Old Aug 18, 2009 | 10:38 PM
Piston454's Avatar
Car: 1990 RS Camaro
so i will proubly have to get a new throttle body then?
Old Aug 18, 2009 | 10:45 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i run a weiand 871 roots blower, 2 800 mighty demon blower carbs on top. easy installation didnt take long and i hit close to 850 horsepower with the motor.
Old Aug 19, 2009 | 07:23 PM
Piston454's Avatar
Car: 1990 RS Camaro
well i was hoping that i could still use a throttle body that way i don't have to mess with the wiring as much.
Old Aug 19, 2009 | 09:10 PM
community's Avatar
Car: 87 trans am clone
Engine: tbi 350 with corvette heads
Transmission: t56
Axle/Gears: 4.11
i run a procharger on my tbi car (which they do not make a kit) i used the tpi kit and added a carb hat and it works great with stock injectors im running 11.5 to 1 air feul ratio and thats with the fmu adjusted down a bit so the feul is no problem and at 5800 feet above sea level i ran a 13.5s 1/4 with a horrible launch do to i will exlod the t5 if i launch how i wanted to anyways the procharger is a great supercharger just if you have a t/a then be ready to get electric fans and a bigger radiator because they like to overheat with the intercooler blocking the radiator just my 2cents
Old Aug 20, 2009 | 06:59 PM
Piston454's Avatar
Car: 1990 RS Camaro
hey thx can u give me the link or web sight where you got your kit?
Old Aug 20, 2009 | 10:14 PM
community's Avatar
Transmission: t56
Axle/Gears: 4.11
i bought the kit used from a guy i know who had a tpi car so really you can get the kit anywh just google it then you will need to buy a carb hat and fab up some 3 3/4 inch pipe to match the carb hat with the tpi pipe that comes in the kit. the only difference in the kit is the carb hat everything else is the same but if you have any other questions just give me a call ill pm you my number so if you have a question about the install i will be able to answer them
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
