Single turbo oil return - anyone made one without removing oil pan?
Old Sep 6, 2009 | 09:37 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I'm running into a difficult time with the oil return location for my single, passenger side mounted turbo. Some people have used the fuel pump blockoff plate but my research along with opinions from some seasoned turbo people leads me to believe this to be a restrictive drain location.
With that in mind, I would like to put the drain into the oil pan. The only logical location is right below the fuel pump area. This problem is my Iroc came with water cooling for the oil and the two lines come all the way around the pan and terminate right in front of the blockoff plate.
Ideally, I could switch over to solid motor mounts, which would give me considerable impovement in locaiton options but I *could* sneak a line between the existing mount and the oil cooler lines. It would be a difficult fit at best, unless I modify the bracket and move the cooling lines down and forward a bit.
Who has dealt with this issue and what did you do? I'd also prefer to just punch the pan and thread a fitting in. I've already got the tool and fitting. It looks like I really need to pull the pan to do it. If I could install the fitting immediately below the fuel pump, I think I can get to it without removing the pan.
Looks like I'm going to be dropping the pan and switching to solid mounts unless someone gives me better news. For that matter, who has used the fuel pump plate as an oil return with any long term success?
Thanks... zz3
Old Sep 7, 2009 | 10:32 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Single turbo oil return - anyone made one without removing oil pan?
I've been using the fuel pump location and have not had any issues. I use a block-off plate with a 12an fitting and 12an return line. Before that I welded a bung in the pan and that worked good too. I did remove the pan though.
Old Sep 9, 2009 | 10:29 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Thanks for the info.. my friend tried this a long while back and had problems but I don't think he had a flow restrictor. He uses pan drains only now so I got his tapped blockoff plate and fitting today. One less dragon to slay. I will put a pan drain in when I get the engine out for a rebuild(shouldn't take long with 12-15 psi lol)
Old Sep 11, 2009 | 04:51 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
my s475 is drained into the fuel pump block off plate with a -12 line....no problems or leaks
Old Sep 13, 2009 | 10:22 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I've been using the the fuel block off plate for a few years... I'm also using a -12 line... Why make it harder on yourself then it has to be????
Ray
Old Sep 17, 2009 | 10:52 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I installed mine without removing the pan. I punched a hole with a centerpunch then drilled SLOW with the proper sized bit covered in grease. I tapped the pan 1/2" NPT. I got a steel -10AN to 1/2 NPT fitting ($.98 from a hydraulic line shop) and covered the threads in JB weld.
I figured if it leaked I could remove the pan and TIG the thing together. It's been holding up just fine.
Attached Thumbnails Single turbo oil return - anyone made one without removing oil pan?-100_0811-1-.jpg
Old Sep 18, 2009 | 12:15 AM
ZZ3Astro's Avatar
Car: 87 Iroc
That whole area on mine is blocked by the oil cooler lines. I had to move them down to even get the blockoff plate return to fit. Now that I think about it, I still need to secure them. The blockoff plate seems to be working out ok for now, but I will do a larger pan return when the engine is out of the car.
Old Sep 19, 2009 | 04:56 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I forgot about that. I have braided trans cooler lines, you can see them in the pics. AND I forgot I have alot more room than an F-body.
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
