cheap nitrous kit or piece together my own?
Old Oct 4, 2009 | 04:55 PM
bmfIROC-Z's Avatar
Im looking into putting a 125 wet shot of nitrous on my car for next year,and i was wondering if anybody knew where to get a decent/cheap kit?or possibly a way to piece together my own kit on the cheap side?im doing some suspension work this year to so i need to do the nitrous thing as cheap as possible,thanks in advance.
Old Oct 4, 2009 | 05:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: cheap nitrous kit or piece together my own?
Harris Speed Works has good stuff at a good price. I ran their single nozzle LT1 kit and adapted it to work in my HSR 383.
150 for a bottle with highflow valve
30 bucks for the mounts
60 for a nozzle
30 for blow down tube kit
70 for fuel solenoid
60 for nitrous solenoid
10 for WOT switch
20 for a TPI throttle body bracket for the WOT switch
Then you'll need to add 15-20ft of 4an line for main feed and then two pieces of 3an line for the nozzle. Harris will make them for you at any length you want. Not a bad deal
But at that rate your already at 400 bucks then add in the lines which may add up to 100 or so depending. The base LT1 kit is 414 already minus blow down tube so you can piece together for about same price
Not a bad kit for the money tho
EDIT; i see you have LT1 anyway so just get their LT1 kit
Old Oct 4, 2009 | 08:51 PM
bmfIROC-Z's Avatar
60 for a nozzle
10 for WOT switch
cool,thats a pretty good price,thanks man.
Old Oct 7, 2009 | 02:34 PM
Chopstix396's Avatar
Give Hawks Third Gen a call or PM and ask about the Brand X Nitrous kits they carry...complete LT1 kits start less than $400
Old Oct 8, 2009 | 11:58 AM
bmfIROC-Z's Avatar
Old Oct 9, 2009 | 11:26 AM
bmfIROC-Z's Avatar
i contacted hawks about that nitrous kit and its about $600 shipped:http://www.hawksthirdgenparts.com/ni...bottlewet.aspx ,is this the kit you were talking about?
Old Oct 9, 2009 | 12:07 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Try here. http://www.nitrousoutlet.com/catalog...del=37&dept=11
Old Oct 9, 2009 | 01:14 PM
bmfIROC-Z's Avatar
Originally Posted by bluegrassz
that must be the one he was refering to,thanks man
Old Oct 10, 2009 | 10:20 PM
Yep...Hawks offers all of the Nitrous Outlet line....the Brand X LT1 kit will work on both Lt1 and TPI cars.
Old Oct 10, 2009 | 10:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah nitrous outlet will work nicely too
Old Oct 10, 2009 | 10:46 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Here you go, I've been running this kit for almost 2 years now with no problem. Earlier this year I replaced the fogger for a plate (I wanted a harder, direct hit) but nothings wrong with the intake fogger...
EBAY
italiano67
Dec 11, 2016 09:21 AM
gixxer92
Sep 1, 2015 04:32 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
NinjaNife
Aug 23, 2015 11:49 AM
