Nitrous lines/nozzle selection
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Can I use flexible lines to connect from the distribution blocks to the nozzle? LTR's with a nitrous port welded in place. Most of the kits I see have hard lines that can be bent to the desired shape/configuration. Any thoughts on the NOS Fogger 2 nozzle? Annular discharge? If you feel there is a particular nozzle I should consider, feel free to let me know. Thanks
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Nitrous lines/nozzle selection
I think you'll be fine as long as they are made to handle the pressure (up to 1500psi). I currently have a steel braided line connecting from the solenoid to the plate (fogger)...
Can I see the braided lines from the distribution blocks to the nozzle??? I called the guys at NOS and they said it might be too bulky / require a fitting to fit the braided line. Are the nylon hoses rated at 1500+ PSI???? Nozzles ideas????
Car: 1989 GTA
Axle/Gears: 9 bolt
why are you scared of bending hard lines?
have you looked into something like this?
http://www.induction-solutions.com/s...roducts_id=189
No not scared, just prefer the look of braided lines. I bought a tube bender from NOS.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
I have run a fogger for over 10 years.and tryed the #4 for the lines.
you can use the hard lines.. will make more room when you go to work on it.. i run a fogger set up..
By the cheap steel lines to work with First..
then when you get it set up the way you want..(LOOKS)
BUY the SS lines get them set up with the same bends.. Buff them out and you will be much more happy with them..
and always support the diss Bocks..or your lines will crack..
the last time i did my lines i took them apart. put some heat to them
to see if i could get them to be a bit more soft. to not crack.
it was always the smaller short lines that cracked on me..
you have the NOS tool. buy some cheap Brake line. work out how you want your bends to look like.. that SS stuff Is spendy. always hang on to your left over SS hard line.. you can have it fixed to use by a hose shop.
as back up line if you get a crack.
a fogger set up will ALWAYS make more HP over
any other NOS set up.. from 100Hp to 600Hp all By it's self..
you Just need the eng that can take it is all...lol
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Lots of guys run standard braided line to nozzles. Harris Speed Works makes custom lines if needed just for that purpose. -3 lines if using -3 fittings or whatever you want/need for your setup. I've seen them make custom direct port kits for LSx setups/sheetmetal intakes/etc using braided lines instead of hard tubing. I also prefer the look of those lines compared to tubing
Well I bought a set of Fogger Nozzles. The soft plume 90 degree in stainless steel. My question is. What is the best Nozzles that NOS makes???
it's how your intake or point you place the Nozzle in your intake.
that makes you pick what one you want..
in my intake i want them to spray down into the TPI Runners.
all 8 of them spray down into the runners.so i use this type
http://www.summitracing.com/parts/NO...S/?image=large
BUT:
are available in standard, 180 degree, and 90 degree left or 90 degree right configurations. These nozzles are made from brass and have a black finish.
THIS HAS BEEN SITTING FOR 7 YEARS. forgive the Dust.
closer look at 90 deg nozzles
this is the same set up im using over. with the new procharger 12psi
and the 427 sbc.
i can tell you back when the old 383 was running..you would Hit this
and the car felt like you just dropped into passing gear!!and would not stop pulling till you let up off the button.
it will be a few less HP Hit.. dropping it down to like 100HP. or less..
all this was done back in 1993. after i got the car back from Lingenfelter.
and the 427 sbc.
Wow, why has that been sitting for seven years? Very impressive! Does anyone else have a direct port setup? Maybe some photos? I was reading this book on Nitrous and they had a photo of a direct port setup done by ASM, anyone familiar? I will post some pictures my of own. I just received the Pro Race Distribution Blocks.
Car: 89 Iroc-z
Transmission: TH400
Here is what I wanted to do before doing twin turbos
https://www.thirdgen.org/forums/post...844-post2.html
direct port on a stealth ram intake
the soft lines would make jet swap out a bit faster.
the hard lines suport all the parts installed on the fogger
and in my photos i did not buff out the SS lines. or they would look like chrome..and doing a jet swap takes a bit of time (16 jets)
PITA. but in a funway.SixSeriesCSi
7 years ago soon 8 years now. THE ENG just stopped
2400 rpm purring along...then just like you turnd it off with the Key
stopped no leaks no drips nothing.. in the photos you can see i took the covers off to see if i droped any thing.. and nothing.. every thing is in its place.. oild is clean antifree is full (7 years later to boot) and it will not turn over even with a big a$$ bar!
thinking a main spun or somthing.. but i pushed it into the shop and there she sits.. but now I dropped another $10.000 into her in the last 3 months. and will see if i can get her done by summer..
the new stuff
dart block 427 sbc (Hbeam rods all forged intrnl)
procharger 12psi
Hooker 2210 cc and all new Y pipe 3" (the photos shows SLP SS 1 3/4 Headers.)
new seats (i dont know why)
all new rubber (for the back another why?)
tube K member
tube A arms
front coil overs
and some other parts... this spring im going to get bissy
If anyone has a direct port setup on the runners please let me see it. I went to fit my nozzles and as it turns out. They won't work. The ninety degree angle of the soft plume would "squirt" on to the runner floor. So I plan to buy the annular discharge nozzle. Which will shoot directly into the base plate at a slight angle.
BUMP!!! For Direct Port Setup.
Ordered the Stainless Steel Annular Discharge Nozzle from NOS!!!. Photo's to follow soon. "I'm so Excited!!"
Is ArticwhiteZ the only Direct Port Nitrous user on the board?
Where all the Third Gen Nitrous Users??? Thread Starter
I have a digital camera now... Pictures to follow!!!
I need to get this running already....
Here are these long overdue photo's enjoy...
Thought I would add these two Photo's, Enjoy...
Thought I would *** this Photo, Enjoy...
Due to the Close Proximity of the Outgoing Ports, a AN Fitting will not be possible. Looks like either Hard Lines or Nylon. If someone has run both a Nylon line and a Steel line, please chime in as to the "Softening Effect" created by the Nylon line, Please. Thank You
I have a shop near my home that makes up braded stainless to suit. They also have the assortment of fittings(Aeroquip distributor). You may have a shop near you. Only teflon racing hose (Aeroquip) can handle pressure. They are highest rated pressure hose (2,500).
I see your proximity comment now. But Areroquip has so many fittings?
I use a Company called Earl's in Lawndale, CA. The guy is an arrogant *****, but he knows what he sells...
"Only teflon racing hose (Aeroquip) can handle pressure. They are highest rated pressure hose (2,500)."
I don't belive this is an accurate statement.
friend of mine ran the "nozzle" setup on an LS1. its a fogger with adapters that fit underneath the injectors. it uses flexible plastic lines from the noids to the adapters. plastic lines work fine for that because there is no real pressure there. anything from the noids to the tank need to be stout. typical stainless braided rubber hoses are not suitable and will blow apart. (i know from experience, lol)
Edit: Only teflon racing hose (Aeroquip) can handle pressure >1500. Their are highest rated pressure hose is 2,500."
A comment was made N20 needs 1500. My NOS system came with braided stainless hose ends attached.
i think a critical piece with the nitrous is the crimped ends. i had 1 hose leak at an end, and another occasion a fitting spit half the hose out blowing shrapnel everywhere and making a gigantic KABOOOOOM. had everyone in the pit area walking out from their car looking down towards me when that happened. lol
and then it occured to me i was doing something wrong. heh.
Car: 89 Iroc-z
Transmission: TH400
I had lines made for me by harris speed works, a known nitrous shop with good priced kits. All the ends he uses are crimped ends on what looks like regular braided steel hose. It wasnt super expensive so i doubt it was special teflon stuff
