What turbos???
Old Dec 18, 2009 | 07:55 AM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
What turbos???
Planing to build a 383 twin turbo monster... im planing to make 700+ hp. Was wondering if there is a twin turbo kit out there to do this or if not wat turbos should i use?
Old Dec 18, 2009 | 08:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: What turbos???
Not really a kit available, for twins that is, but some single turbo manifolds available.
Turbos really dependant on what build specs of the motor are and is that 700whp or crank?
For a good street strip setup 60mm turbos like I have on my car will do 700whp easy.
Old Dec 28, 2009 | 04:19 PM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
Re: What turbos???
Actually I found a twin turbo kit for the 1982-1992 F-Body cars. I don't know if this kit is any good or not, but there are a few besides the Ebay kits. I actually thought about ordering their top mount turbo manifold as I don't have the stuff needed to fab them.
Old Dec 28, 2009 | 04:31 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: What turbos???
that looks just like the ebay kit to me. Probably made in the same factory from china...
Old Dec 28, 2009 | 04:54 PM
Engine: 305TPI
Re: What turbos???
It could be. I'm new to the world of turbos in general so I'm trying to learn all I can right now. Are the turbos in that kit just Chinese copies of the Garrett turbos?
Old Dec 28, 2009 | 05:20 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: What turbos???
yes. There are one or two brave people on here that have bought the ebay kits and tried to install and make work. But I have yet to see one of those kits installed and fully functioning. I have also seen (on different sites) those same turbos litereally broken in half. Same with the headers, flanges just break off from the tubes. I think someone bought those headers and tried to make it work but the tubes would hit the other accessories (specially the steering column-linkage) and possible brake lines by the booster... A good reliable turbo will probably cost you as much as that whole kit...
Here is a few pics of the SSAutochrome/ebay stuff
header
Turbo
Before
After, large crack down the middle...
Old Dec 28, 2009 | 08:20 PM
Engine: 305TPI
Re: What turbos???
Well I'm a firm believer in doing things right the first time. So I want to get a good solid turbo or set of turbos that will last.
Old Dec 30, 2009 | 10:38 PM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
Re: What turbos???
I am building a 383 single turbo setup with a Precision 88mm turbo. I found a guy named Jon at LT1Boost. I can't remember if its .com or .org. He has a web site and build me a sweet set of manifolds/headers for my second gen. It mounted the turbo up font towards the pass side and fit great. Built thrm from tons of pics and measurements. Not cheap but cheaper thsn having a trace shop build them and he used quality tubing, flanges, collectors, and v band clamp for the cross over tube. Its worth contacting him for whatever you choose, single or dual turbos. Good Luck!
Old Dec 30, 2009 | 11:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: What turbos???
What are the specs. on the header tubing? thick wall or just 16 ga. MS?
Take a look at the page with the discounted kit. The last picture has a close up of the welds.
All of the kits have an under-sized DP for the HP rating of the kit. Can you keep the inner fender well with the 88mm kit? The good thing about the 2nd gen. is that a 4" DP fits. Which is the minimum you need with that 88mm.
Old Dec 30, 2009 | 11:51 PM
andrewmp6's Avatar
Re: What turbos???
Never buy anything off ssautochrome you see way in the pictures.I bought a manifold for a rb25det off them years ago it wouldn't even fit and once i made it fit it leaked like hell.Gale banks did make a twin turbo kit no clue on price of if it would fit in a 3rd gen.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
