sbc 383 w/10:1, with sn92,,will it work?
Old Dec 29, 2009 | 12:47 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I maybe getting a 383 shortblock from a member to replace my worn 350. He told me its 10:1. I currently have a sn92 thats pushing 5-7 psi on the 350 but I know itll drop with the 383. My 3 questions are;
- will the 2-4 psi make noticeable gains with the new setup since its a higher compression motor?
-would I be better off going N/A and not have the SC putting more load on the crank pulley?
- should I stick with the CC276hr12 cam I have now in the 350 or should I go larger?
PS, I know the sn is too small and eventually it will be replaced but for the next 3-4 years its not in my budget
Old Dec 29, 2009 | 01:18 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: sbc 383 w/10:1, with sn92,,will it work?
I say run the blower man, you have it, no reason not to!
If you have the funds to get a new cam I say definitely get one tailored to a 383 with a blower to make the most of the combo.
Old Dec 30, 2009 | 03:40 AM
1bdbrd's Avatar
Car: 1991 Trans Am
You will make more power sure, but how much could you sell the entire blower setup for? Could it be sold for enough to purchase a great top end for the 383? If so you could be looking at the same power either way and less strain on the crank.
Old Dec 30, 2009 | 07:13 AM
AC's Avatar
AC
Car: Used to drive a camaro
Hmmm, I don't like the fact you'll not be running anything to combat the blowers charge temperature going into a 10:1 CR motor. You'll probably see 5psi on your 383, thats what I used to about average. I wouldn't mount that blower on a 10:1 motor until you have either methanol injection or an intercooler, but thats just me.
If you don't care then mount the blower and then come back and post how she felt.
Old Dec 30, 2009 | 07:22 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Whats wrong with the topend I have?
Originally Posted by AC
Hmmm, I don't like the fact you'll not be running anything to combat the blowers charger temperature going into a 10:1 CR motor. You'll probably see 5psi on your 383, thats what I used to about average. I wouldn't mount that blower on a 10:1 motor until you have either methanol injection or an intercooler, but thats just me
If Im seeing 5 psi right now then Im definetly going to see a drop with the 383, also Im getting a bigger pulley to slow the sc down a bit to cool the charge down.
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
