88 formula tpi twin turbo setup
Old Jan 7, 2010 | 01:01 PM
sd88formula's Avatar
Car: 1888 firebird formula
Engine: 350ci 5.7L tpi
Transmission: 5 speed
Axle/Gears: 12 bolt posi track
T3/T4/T04E Turbo Charger x2
Turbine Turbo Charger
Oil Cooled Only
6 Blade Propeller
May modified to use external or internal wastegate
Compressor Specs: Turbine Specs:
      • 3" compressor Inlet - T3 Type Turbine / 11 Blade Type / 2.25" Exducer
      • 3.000" or 76.20mm Major - Exhaust Outlet Flange with 5 bolt design
      • 1.988" or 50.50mm Minor - Turbine .64 A.R. / 76 Trom
      • Compressor .50 A.R. / 57 Trim - 2.560" or 65.04mm Major
      • M24 / T4 Compressor Housing - 2.204" or 56.00mm Minor
Turbo Manifold w/ External Wastegate Flange
Uses T3 Turbos and External 35mm/38mm Wastegate
Able to Keeps Power Steering and Air Conditioning
38mm External Wastegate x2
Utilize 35mm/38mm Flange
Direct Bolt-On Twin Turbo Intercooler (32" X 5" thickness, 3" inlet)
Can Hold up to 1k+ CFM
Supports up to 15 Psi
Piping Kit (2x U-Bend + 2x 45 deg + 2x 90 deg + 2x straight pipe)
2.5" Piping
8x Silicone Couplers
16x Stainless Steel T-Bolt Clamps
Turbo Boost Controller
1-30 PSI Adjustable Increments
Blow Off Valve
Slim Turbo Timer
Oil Catch Can Tank
Vacuum pressure Sender Adapter
Braided 1/8 NPT Turbo Oil Feed Lines x2
3/8 diameter stainless steel braided lines
Length = 36"
Turbo Oil Return/Drain Lines x2
    • is there anything else that would be needed to complete the kit or would i be good to go?
Old Jan 7, 2010 | 01:06 PM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
Re: 88 formula tpi twin turbo setup
Is this a kit you found somewhere or a part list you put together yourself?
Old Jan 7, 2010 | 03:33 PM
its a kit for about 1,800 would you have to get any adapters for it to hook into the plentum?
Terrell351
Jun 13, 2021 01:13 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
Sanjay
Aug 12, 2015 03:41 PM
