Electric turbo charger?
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
I am sure everyone has seen the cheep electric turbo chargers on ebay that dont work, I am also pretty sure everyone has seen the dyno pull video where they stuck a leaf blower in the intake tube while making a pull and actually gaining 20 or 30 HP. Now what if someone was to take an electric leaf blower, seal it tight to an intake and power it with a 12v to 120v inverter? Guys with a Carb or TBI could run a dual snorkel filter housing and actually run two.
I think the idea is actually feasible the only problem I could forsee is controlling the blowers speed, maybe let it run wide open 100% of the time and get a BOV and set it for a ridiculously low pressure like .5 or 1psi of boost so it would open when the butterfly's in the throttle body close and keep from burning up the leaf blowers.
What do you all think? Feasible? Think you would see any performance gains? We are actually thinking about doing something like this on my friends 118hp 4cyl nutless wonder isuzu amigo 4x4.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Electric turbo charger?
NO.
They just move air. You need something that positively displaces air. not just pushes it around. This topic has been brought up a few times in this forum, do a quick search and you will see lots of reason's it doesn't work.
I have never seen the video you are talking about, but I seriously doubt that dyno video is not some how fudged.
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
If anything, they would be a restriction in the intake at higher engine speeds. I'm sure it would somehow help at very low engine speeds but higher in the RPM band, you would see a huge restriction. Also, when you load the alternator down with that kind of electrical load, you will see a decrease in performance.
I have seen a video that there was an increase on I think it was, a Tahoe, but they sprayed nitrous through the leaf blower, into the intake. The gains were from the nitrous, not the actually leaf blower.
I don't shoot down any performance mods, so I will try my best to help you. If you do this in a dual snorkel setup, put the leaf blower in only one side of the intake, this way it can feed from the otherside and not have a restriction. You may also want to take out the air filters to feed more air in. I know that sounds dangerous, but that leaf blower is going to be a restriction in the mid range, on up. If is just air flow dynamics, no way around it.
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
agreed, if you read the cfm flow numbers from those, they don't even flow enough air for a stock v8.....it would just be a restriction.
Car: Firechicken
Please note, the OP wishes to put this on a 4 popper, so it wouldn't be such a restriction on that 4 banger as our V8's.
Car: 1984 Trans Am
Here is the video http://www.streetfire.net/video/Leaf...-Dyno_7514.htm
Car: Firechicken
Can I ask why we don't see a dyno run before the leaf blower? Also why are the cross over points on the Civic different between dyno charts? Also, do you plan on running a giant extension cord to power a blower, if not, and you go gas, how do you turn it on and off?
I find some problems with this video. Sorry, but also, a car uses a crap load of air, so to positively displace air, you would need alot more air. You are saying that you can't hold your hand over the end of a leaf blower, but a leaf blower is focusing air on a small space, you need more than velocity, you need volume. Can you suck your hand in on the intake side of a leaf blower? See the difference. You are making volume into velocity, but you don't have the volume for positive displacement.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 2.6 litre engine would displace 200 CFM at a little less than 2200 RPM.
A typical leaf blower draws about 12A at 120V, that's 1440W. Assuming your inverter is a generous 90% efficient, that's 1600W. At 13.8V, that's about 116A, just for the blower. A car alternator is only about 50% efficient on a good day, so you're going to put at least a 3200W load on the engine, which is about 4 HP.
Car: Firechicken
That just looks dumb. For the same money spent on those leaf blowers, the fab work to make it work, and whatever tune, it would have been cheaper to throw a cam at it, or a bottle at it. What a waste of time and money.
NO.
The problem is that they are just too small and use too much power. In most cases you'll need a 2000watt inverter (wired with 2 or 4ga wire...) and you'll only get enough airflow for a few HP on a small engine, one that will have problems with that kind of power draw to feed the inverter. Electric motors and storage just isn't efficient enough to make this worth doing.
Additionally, the videos showing this working are usually involve an engine being sprayed with N2O, which have typically have a problem with keeping the intake air charge going in the right direction (if you've ever watched a carbed N2O engine on a dyno typically you'll see a cloud up above the carb, a little bit of pressure preventing that is worth a few hp).
Except that turbo's compress air, they dont' just push air around. Turbo's pull air in from a then send it out through a smaller on, positively moving/displacing the air. Unlike a leaf blower that is just a fan spinning that pushes some air into a tube. Just like was stated here, speeding the air up, not compressing it.
Engine: 383 Carb
Transmission: 4L60
A turbo's not a positive displacement pump, it's just a fan spinning that pushes some air into a tube. Take apart a leaf blower and you'll find a centrifugal fan and a discharge port that's vastly smaller than the intake, too.
Car: '85 IrocZ
Correct! A turbo is considered a Non-Positive Displacement pump, as it moves a continuous amount of flow, not a discrete amount. There are some other characteristics that define positive and non-positive displacement pumps as well. Your water pump and any other centrifugal type pump is non-positive.
I stand corrected. I guess I should not speak about what my knowledge is limited in. I had assumed Turbo's were positive displacement like blowers are. Hell I wasn't even aware that Superchargers are dynamic until about 5 minutes ago.
Roots and other similar screw or lobe type blowers actually compress the air. It makes them interesting to tune with computer controlled setups, since you can usually see the pressure pulses coming out of the supercharger in the datalogs.
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
No, he's wrong. Turbos are compressors and actually make pressure and airflow. Now that compressed air quickly expands to normal atmospheric pressure if it isn't contained by say the intake manifold. High speed air getting slowed by the compressor housing is what creates the pressure. So the air exiting the turbo compressor is actually compressed.
A roots supercharger by contrast makes no pressure inherently in it's design. It is a pump, not a compressor. It makes pressure by moving more air than the engine can consume.
A screw supercharger is however a compressor. Air exits the housing with an inherent pressure ratio.
Now, there's no reason you couldn't have say a electrically driven centrifugal compressor. Driving a compressor large enough to produce meaning boost could take anywhere from 20 to 60 hp. The problem is generating that much electricity is really beyond the ability of a typical alternator.
As for why leaf blowers are silly, well they aren't exactly built to tight tolerances so you'll like get air bleeding back to the inlet rather than a lot of meaningful boost.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
I did this once to a POS civic . It worked . I will not explain why or how nor do I know why or how it did it worked but it did. Not alot at all but there was a noticable differance . The car also had a cardboard body kit and a bean can (a real baked beans can) and was the biggest waste of metal on this planet , thats why we did it . Please dont do this to a third gen . These cars dont have a very good rep as it is . Dont make it worse.
Car: Firechicken
Haha, he said bean can! At first I thought you were going to say something racist, but nevermind, that is so funny, and a cardboard bodykit, that should've weighed less than carbon fiber!
On a serious note, maybe it worked on the honda because of it being a smaller engine, but I don't see it working on a big V8, especially a 350. I would still see it as an airflow restriction.
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Here's the video everybody's talking about:
http://www.youtube.com/watch?v=UQ7YWT6rX0o
We gotta send this idea to that MythBusters show on the Discovery Channel... see what they have to say.
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
look at my videos I have had several electric superchargers and i even measured the oxygen with a sensor. watch
http://www.youtube.com/watch?v=P_hWEqKzoaQ
TMZIrocZ350
Oct 7, 2015 12:09 PM
