rebuilding motor advice??
Old Mar 28, 2010 | 10:05 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
Well, I thought i was loosing pressure on my number 6 cylinder later on found out the piston failed on my setup.... Anyways now building a new setup. going to be using the zz 383 880 block, forged 4340 gm crank. I was going to get forged h beam rods by scat and forged diamond pistons with 8.5 to 1 compression on my 62 cc fastburn heads. the cam i just bought is a custom grind lunati roller cam with 226/238 and 558/560 with 114 on 1.5 roller rocker. using 1.5 gm roller rockers and then my superram intake and a 52mm throttle body. then going to be using my d1sc procharger and was going to make about 15psi. is this setup ok on pump gas. hoping for 600ish hp. does this setup sound ok anyone??
jhawkeye
May 25, 2022 06:33 PM
italiano67
Dec 11, 2016 09:21 AM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
slade5612
Aug 11, 2015 07:19 PM
