Nitrous wiring question?
Old Apr 19, 2010 | 11:19 PM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Axle/Gears: 2.73 / Stock
Hey all!
Before i get done wiring my nitrous system up i thought i should double check to make sure this is going to work correctly.. Here is the diagram i was givin to follow.. However i dont have the MSD rpm box, i have the summit racing SUM-830452 switch
However I am kinda confused as the switch i have has 2 grounds. Blue wire is ground outside of the window and purple is ground inside the window. I'm not wire savvy obviously but I'm guessing pin 85 on the relay is the ground side and when the rpm reach the certain rpms the switch will finish the ground allowing pin 87 to complete its circuit turning on the noides? Am i correct on this?
Old Apr 19, 2010 | 11:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Nitrous wiring question?
yes, 85 on the Relay is Ground, and yes the MSD close and opens the ground circuit inside the window.
you would use the Purple on the Summit to close the circuit.
Are you going to use the Fuel Pressure Safety Switch as well?
Old Apr 20, 2010 | 12:08 AM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Ok so the purple wire hooks to the FPSS. And yes i will be using the fpss also. I have everything in the diagram except for the msd switch. Just wanted to make sure this was how it should be setup so i dont go oops! .. Thanks for your help and quick response!
Old Apr 20, 2010 | 12:30 AM
Zepher's Avatar
yes, purple to the FPSS.
Old Apr 20, 2010 | 11:45 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
That is a very good wiring diagram!
Cleotiz
Jan 6, 2018 08:56 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
