D1sc instructions and help anyone
Old May 26, 2010 | 09:18 AM
85berlinetta383's Avatar
I recently purchased a semi complete thirdgen pro charger kit it's the d1sc with intercooler. The main problem is it was modified for an ls motor so I have to reassemble the small block standard bracket setup and tensioner. I have most of the stuff except for some of the piping. It's a carbed 383 roller block 1 piece rear main seal. I have afr heads no power steering or ac anymore. The alternator and water pump are run off a v belt and I was planning in just adding the serpentine belt for the pro charger. Can I mount the crank serp pulley overtopping of my v belt crank pulley and keep the rest as it is?? I didn't get any instructions which would be a big help with the install if someone has this it would be a major help and or a step by step install with pics. I have a boost ref fuel regulator and an A1000 fuel pump, csu 750 blowthrough carb, extreme velocities carb hat. Just seeing what I should be ordering to help me out and anyone with tips who has done this already would be greatly appreciated.
Old May 26, 2010 | 11:50 AM
KS91Z28's Avatar
Re: D1sc instructions and help anyone
You're best bet would be to use ProCharger's "Carb Chevy" bracket and crank pulley. Otherwise, you'll have to install the '88-'92 serp brackets and accessories to make your bracket work. If this is clear as mud, give ProCharger a call.
Old May 26, 2010 | 11:56 PM
hmm so this bracket I have wont work is what your saying?? has anyone else tried doing this with the kit??? noone has a link for proper install instructions??
Old May 27, 2010 | 04:59 PM
KS91Z28's Avatar
Give ProCharger a call. They can fax or email you a few pages from the manual. It'll be a lot easier to understand why it won't work then.
Old Jun 3, 2010 | 04:05 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have the Carb bracket with my D1-SC in my 92 and running a 12 rib blower belt with a V-Belt style crank pulley. This seems to be the way to go, this way I'll have room to grow if I want to go to a larger unit like say a F1 series. I have a few pics of the motor on my car domain page in my signature. Page 8 has the best pics.
Elephantismo
Feb 13, 2019 12:51 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
