Installing an intercooler
Old Aug 23, 2010 | 11:31 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
Do you guys think it is necessary to take the nose of the car off to install an intercooler?
Old Aug 23, 2010 | 11:50 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Installing an intercooler
Depends on the IC, but if you plan to install it like procharger does its not necessary.
Old Aug 24, 2010 | 05:49 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I installed one vertically on a 92 RS and it didn't require removing the front bumper.
Old Aug 24, 2010 | 06:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
YOu can do it without. With it off, its easier but depends on the size and where your mounting. Using the crash bar for support or closer to the rad?
Old Aug 24, 2010 | 10:35 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
You must have removed some stuff in order to expose your IC like that correct? I was able to get 31x12x3 in there without much hassle at all. Mine isn't exposed like that though.
Old Aug 24, 2010 | 10:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i had the nose off the car to pull the motor and get the nose repainted. I cut the crash bar out between the factory frame rails and then welded in brackets to bolt in this intercooler.
factory grille/fog lights and etc have been removed. Probably be best to remove nose to cut that crash bar out. Not sure how easy it would be to cut that out with nose in place
Old Aug 25, 2010 | 11:17 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
If I don't remove that section of the crash bar how effective do you think my IC will be up to around 15 psi of boost? I will probably be running meth/water injection anyway. I'm hoping that I will still see enough air flow to keep IAT under control. What do you think?
Old Aug 25, 2010 | 12:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Should get some air flow thru there. These cars do see alot of air flow up from underneath. It also would be helpful if you add an air dam in front of the intercooler to bring air up thru the intercooler and the air can channel back to the radiator.
If the intercooler is big enough it should be fine for 15psi.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
redmaroz
Apr 25, 2017 07:14 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
toronto formula
Nov 10, 2015 06:17 AM
