Ysi 355, AFR 195 heads, 8.5/1 compression, TPI.... need cam help
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Well, a couple months ago I bought a 1987 Iroc off of here from "zdaddy". It currently has a 305/ysi combo making 664 on 16psi. We will be upping that to over 20 and looking for near 800hp once we fix a couple blown head gaskets...
The point of this post is the 355 that we built for my other car(that is now sold) and when the 305 goes we will be upping the cubes(hopefull in at least a year so I can get some fun out of the car now
Combo:
355
splayed 4 bolt
Carrillo 6"rods
CP pistons
ported AFR 195cc heads
8.5/1 compression ratio
induction: ported plenum, 1/2 siamesed SLP runners, ported Edelbrock base and 58mm TB
exhaust: Hooker LT's and true duals/dumps
I had a cam picked out and we installed...
http://www.compcams.com/Company/CC/c...?csid=304&sb=2
Anyone running this type of cam and getting good results with a supercharger this big? it would of worked good with my T6 flanged S400, but not so sure of the big SC with the 110 lobe separation...
BTW Vortech was NO help at all
)...Combo:
355
splayed 4 bolt
Carrillo 6"rods
CP pistons
Dialed_In
Aug 20, 2015 01:45 PM
