S/C TPI 350 Questions
Old Nov 16, 2010 | 07:39 PM
regular6d's Avatar
Car: 84 Z28, 05 Mazda 6
Axle/Gears: 3.42 Open
Building a TPI 350, blew up my old Carb'd one. Spent waaayyyy too many hours in the garage reading posts titled Should'nt be left alone... Decided I wanna try and FI this TPI. M90's are all around for short money and if I use the same method's I've read about what else do I need? For example, do I need to upgrade my injectors? It's a MAF engine should the MAF stay in stock location, and if I mount the M90 and line everything up will I only need to get a longer serp belt and a tensioner? Also I think I know the answer to this one but I'll ask anyways, No driving without a tune right???? Any info would be awesome the engines sitting on a stand in the garage, engines up in the air on my lift, and I just get to stare at them until I get my wiring harness. Atleast they'll be painted on every services.
Old Jan 7, 2011 | 11:58 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: S/C TPI 350 Questions
i would use the megasquirt II for tuning and toss the maf. and yes bigger injectors. i would set the spark table to retard 2 deg per psi.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
