What cam to run.
Old Dec 6, 2010 | 10:52 AM
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
What cam to run.
I wanted to see what cam everyone is running and if anyone knew of any other companies to call.
I called comp cams and they only reccomended like a 507 lift.
Old Dec 6, 2010 | 11:03 AM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: What cam to run.
This is a really vague question.
When choosing a camshaft there are several things to consider
EFI/Carb?
Rear gearing and transmission?
Displacement?
Daily driver/street strip/drag race/autocross?
Old Dec 6, 2010 | 11:06 AM
Eric89sc's Avatar
Car: 1989 camaro
Ok its for a carb 355 motor with F1-A procharger with 18 lbs of boost. I have a turbo 400 with a 3.42 rear end.
Old Dec 7, 2010 | 08:30 PM
pajama sam's Avatar
its not so much about lift as it is about duration. for my build comp cams sent me a 230 duration and 530 lift. 114lsa working amazing right now
Old Dec 7, 2010 | 09:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
what heads/intake?
RPM range that blower is able to make 18psi at?
good place to start... www.jonescams.com or http://www.smreperformance.com/smre-...lications.html
http://www.ultradyne.com/
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
