nx plate question
Old Jan 16, 2011 | 01:05 PM
gtanut's Avatar
nx plate question
i have a nx gt pp plate with spray bars and the throttle plates on the carb 850cfm are hitting the spray bars has anybody seen this before and would it hurt to run a 1/2 spacer on top of the plate to correct this problem thanks alot
Old Jan 16, 2011 | 01:34 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Re: nx plate question
They should not hit IMO. You can put a carb/manifold gasket and a 1/2 inch spacer on top and it would be fine. But you should not have to. I have a NX gemini twin stage 6 plate system Im trying to setup and am having bigger issues with it. So far I am very disapointed with the NX plate system fitting properly.
Old Jan 16, 2011 | 01:57 PM
gtanut's Avatar
my plate has 8 total spray bars i think that is why the larger throttle plates of the 850 hits what problems are you having
Old Jan 16, 2011 | 10:08 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
The plate is a tapered open plate (Halo/perimeter Zex type) the hole is way small and it obstructs the flow of A/F from the carb. I still have not figured out how they want this plate set on the manifold . Seems like the design was for a 1" thick plate but was machined from 3/4" thick material. If it was 1" thick, the tapered bore would be the proper size and it would be fine. If i put 1/2-1" spacer on top of it , the bores of the two spacers will not line up. The nitrous plate being to small would obstruct the flow from the carb. I will contact NX this week about it.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
69 Six Pack
Oct 5, 2015 07:51 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
