Plastic Vic Jr style intake for gen 1 now available!
Old Jan 12, 2011 | 10:19 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
FYI, a plastic intake is now available from AFR for our engines. It's not exactly fuel injection ready but they do have bosses for injectors. At $600 it ought to have fuel rails and be injector ready though!
This is the first aftermarket intake that I've been excited about though. I just wish someone would make plastic runners and upper plenum for TPI!
Old Jan 12, 2011 | 10:55 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Plastic Vic Jr style intake for gen 1 now available!
Actually, in your case, you would only need a plastic elbow w/that manifold, as being your running the Megasquirt you can essentially run any throttle body that you want to that would bolt to it....
Old Jan 12, 2011 | 11:57 PM
ZZ3Astro's Avatar
Car: 87 Iroc
True but I like the TPI's look and long runners for my application. One thing I don't like about tpi is there is so much surface area to absorb underhood heat. Plastic would be a nice upgrade in this area.
Old Jan 17, 2011 | 11:53 AM
bduffey723's Avatar
Car: not a camaro anymore
my buddy has a cobalt and my girlfriend has a 240sx and both of them have had thier plastic intakes blow into pieces with a nitrous backfire.. anyone on here have any personal experieces with thme? id love to get one.
Old Jan 17, 2011 | 03:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I'd like to see it tested under boost. I have read Tony Mamo's responses to this intake and its been pressure tested to high pressure and show no signs of leaking or blowing up so thats a good sign
Seems like a great idea to beable to adjust plenums and runners on this intake but not sure if that would significantly help a EFI motor as much as it would a carb setup. Plus i'm not sure how you'd "plastic weld" injector bungs into that intake. Those spots onthe manifold look like nitrous nozzle tap locations and not for injectors.
Old Jan 17, 2011 | 03:42 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
I'm assuming the main advantage of this would be to cut down on heat transfer. However, I'm curious on what other advantages plastics intakes pose.
Old Jan 17, 2011 | 04:17 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
they're light.
Old Jan 17, 2011 | 04:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well this design featured an adjustable section to change runner/plenum profiles, or atleast thats my understanding.... thats the main advantage so you can dial in the power curve for the combo.
For a carb motor thats more important because you can run a single plane intake on a stock cammed L98 EFI motor and it would run well, but that intake on a carbed L98 wouldnt run well at all.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 12, 2015 11:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
