89 Iroc Sbc400 TPI Megasquirt Single GT45 5-600 rwhp build
Re: 89 Iroc Sbc400 TPI Megasquirt Single GT45 5-600 rwhp build
lil bit of progress
dam megasquirt wasnt here so probably get it tommorow
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
You stepped up to the 2-Litre Coke bottles now I see, ehh....?
It's coming out sweet bro, what did you use to polish the valve covers....?
Edit: Remember to put the PCV valve on the drivers side valve cover....
going to hit the valve covers with the metalic silver base then the blue
did i mention i dislike chrome
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
so that's what they look like...
i did this yesterday took some time and thank god the wife is 800 miles away because i don't have a sheet metal break but the dining room table with a few clamps and a extra long prybar did the job... i can't show those pics due to my JOINT FILING status having it's perks.
sorry think this posted incorrectly...
ENGINE LOOKS SWEET! nice job
mega squirt is here now its a ms 2 v3.0 not a 3.57 like the seller told me,sent him a pm,
the harness that came with it was a lil messy so i redid it.
even not being a 3.57 its still the same ecm just not surface mount stuff and if i want to add stuff i might have to solder a few things instead of moving some jumpers around
still waiting on 1000 cc injectors
turbo should be here by friday
didnt get crap acomplished today was to busy sorting this stuff out
lol gota be prepared for the zombie invasion
megasquirt should be installed today and hopefully i can fire the car up for the first time since i striped the carb off it last week or whenever the hell it was
You got ways to go before firing it up though, no? That TPI setup was off of an '89, so you need to elongate the center bolt holes to get it to seat. Which intercooler are you planning on running, the same one that I am ($100.00 ebay one)....?
31x12x4 inch core
tpi has already been modified to fit the heads
harness is made for the ms unit already
alls i need to do is drop in the new tpi gaskets plug in the injectors and turn the key, going to drive it n/a till the turbo gets here this friday and i cant actually install the turbo till i have injectors here, so by mid next week i should have everything
50mm wastegate w/10 psi spring
intercooler
100# injectors
2x rfl bov's
and all the misc piping and flanges i need
then i just have to weld it all up
intercooler
100# injectors
2x rfl bov's
just purchased this intercooler and some 2.5 inch tubing for my crossover
just need to make the 2 hour drive upto salt lake city and go pick it up this weekend
intercooler is 31x13x4
well i had to settle for some 65# low z injectors for now but there on there way
i did pick up a huge deal today though
miller millermatic 130 mig with argon/co2 tank for 100 bucks
now alls i need is my 5 inch vband for the downpipe and some 5 inch mandrel bends which im going to order up tonight
wiring harness made and ready to go in
its 70% installed unfortunatly rain showers stoped my work soon as the rian stops ill go out finish and grab some more pics
megasquirt is wired unfortunatly i didnt relize i had the wrong iac and tps pigtials, not that it matters i have the right ones and i need to shorten up the wires for them anyway.
wires for the dizzy need to be shortened way up too
need to wire up the ignition bypass relay thats sitting on the heater box
power and ground wires are a lil long might trim them back or wait till i get the 5 inch downpipe in so i can make sure they are routed far enough away
also pictured is my fuel line feed line repair ive dcided to wait till my presision 65# injectors get here before i try to start the car, no sence in putting it all together to have to take it apart and risk tearing the intake gaskets when my injectors will b here saturday
and my only high $ part on this low budget build lmao
though i cant really say they are high $ i o nly paid 250 brand new for them
Originally Posted by project89
even not being a 3.57 its still the same ecm just not surface mount stuff and if i want to add stuff i might have to solder a few things instead of moving some jumpers around....
my megasquirt is already setup for gm hei i got mine used and the guy was using it on a sbc
u dont need that hei kit, the mod involves 2/3 jumper wires that u can make from 2/3 pieces of extra wire
if u get a v3.0 ms i can take pics of mine and show u were to put the jumper wires
Good deal, I mentioned that above because you were looking for pigtails in my thread and I thought you had the wrong harness. The kit is cheap enough to buy if I decide to go with the MSII, and the video for the mod is here....;
http://www.diyautotune.com/videos/pr...hei/mk-hei.htm
njo haness isnt wrong i just have the wrong year tpi setup, the harness was setup with the flat aic and the round tps connecters. i need the square iac , and flat tps
njo haness isnt wrong i just have the wrong year tpi setup, the harness was setup with the flat aic and the round tps connecters....
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
i was wondering if the 60lb sema deka injectors are any good?
does the lt1 tb bolt on ?
id say id take it but im broke again atm
dont get paid again till next week and i still need that non ac heater box from ya so ill see what happens when i get paid if i can ill pick boh up from ya
ive never heard anything bad about them. The ones i have are low-z but they do make them in high-z as well
im going to install them today, and shouldnt be to long after that ill have the car running so ill let u know my thoughts on them
It's gotta be cleaned, and you would have to swap linkages from your stocker to the LT1 because the throttle cable is different (wrap-around). Post a picture of the MSII harness connectors for the TPI and IAC, I want to see if they will connect to it....
Have one of these too, also needs to be cleaned....
Car: 1984 Trans Am
Axle/Gears: Stock
I am running megasquirt on my TPI as well. It was a thing of beauty to see everything working after a lot of hard work. (megasquirt was my first real soldering project) With regards to the HEI ignition: Are you running direct coil control or are you using the stock ignition module? I am running the direct coil control. Here is a hint for you. With the advance set at the required 26.3 deg the distributer (body) is set to nearly no advance. Simply put: the coil connectors off the driver side of the coil are nearly perpendicular to the center line of the car. Once I figured this out, my motor started up consistantly.
will the tps and iac bolt onto my tpi tb??? lol my tb s much better shape
deffinatly need that thermostat housing too
will the tps and iac bolt onto my tpi tb??? lol my tb s much better shape, deffinatly need that thermostat housing too....
Car: 1984 Trans Am
Axle/Gears: Stock
If I were to go that route, I would obviously be starting from a carbureted application in which was converted to TPI. Other than the pigtails for the sensors and injectors I have no harness whatsoever, so what would be needed in my situation. Is it just a matter of getting the MSII unit, MSII HEI input kit and MSII Relay Board...?
The MSII HEI input kit I think is only for the 3.57 (already assembled) board. The reason why I went with the direct coil control is because it was the most simple wiring and system control. Direct coil control (with the relay board) only requires 3 wires. Coil + (comes from the existing wire on the car) Coil - (goes to the relay board) and One wire from the VR sensor. And thats it. (See also the megamanual page on direct coil control.)
What distributer (and module if any) do you have? The megamanual has a page dedicated to how to wire different HEI modules. The DIYautotune.com page also has a write up on the 8 pin distributer.
http://www.diyautotune.com/tech_arti...part3-nova.htm
When converting from a carb, you will also need a fuel pump that can supply suficient fuel to the rails & fuel lines than can handle the flow and pressure.
I suppose I ought to start a thread on my TPI/Megasquirt setup (in progress). Let me know, and I will start it this week.
For my application I purchased the MSII v3.00 (build it yourself), Relay board, Relay Cable, and the 12' of wire to build your own harness. (all from DIYautotune.com).
Originally Posted by Spin_Phoenix
This is a rather complicated question that needs some more information to give a "short" asnwer. This post may be able to get things rolling. The MSII HEI input kit I think is only for the 3.57 (already assembled) board. The reason why I went with the direct coil control is because it was the most simple wiring and system control. Direct coil control (with the relay board) only requires 3 wires. Coil + (comes from the existing wire on the car) Coil - (goes to the relay board) and One wire from the VR sensor. And thats it. (See also the megamanual page on direct coil control.) What distributer (and module if any) do you have? The megamanual has a page dedicated to how to wire different HEI modules. The DIYautotune.com page also has a write up on the 8 pin distributer. When converting from a carb, you will also need a fuel pump that can supply suficient fuel to the rails & fuel lines than can handle the flow and pressure....
rob u just need a few relays , one for the fuel pump, one for the fan(s)
the only extra wiring is the 12V feeds to the relays
its simple Junior Member
Car: 1984 Trans Am
Axle/Gears: Stock
Project89 is correct.
Sorry I interpreted your question wrong.
I went with the relay board because (for me) it eases the wiring install and consolidates the additional fuses and relays at one location. It also protects the ECM from any voltage spikes. It is fairly simple to use the stock ignition module, especially if you have the relay board. I chose to bypass the module so I could use the FIdle relay for another purpose. (coolant fan or TCC lock up). In my opinion using the Ignition module with megasquirt is the same as having a control system control a control system to control a device. (convolution intended)
.... which diagram is the above for, all of them? How does the Megasquirt compensate for knock w/out an ESC module, and/or any knock sensor feed? I'm assuming it has a built in MAP sensor because I don't see one. Where can I download the software (I'm assuming it's free) to adjust my fuel and timing. Megasquirt is open source, right?
Car: 1984 Trans Am
Axle/Gears: Stock
Megasquirt can control timing and advance internally. It has provisions to receive a knock sensor signal. The knock signal (from the stock knock module) is sent to MS via a spare input. Once that input is detected (and various other conditions met) MS retards the timing. Apparently, this is in the prototype phase (per the megamanual website). As far as I understand, without the ESC module, (and knock sensor) MS cannot retard timing by itself.
see: http://www.megamanual.com/ms2/knock.htm
The MAP sensor is built right onto the board.
You can get the software from this link:
http://www.diyautotune.com/softwarelinks.htm
The Megatune software is open source.
Interesting. I'm liking the whole idea behind the parallel installation....
I noticed you have a non-CSI plenum. Be warned you need to drill a hole or something for the IAC valve. I spent 2 weeks trying to start mine without the IAC being there and unable to figure out why it didn't work.
Originally Posted by Drac0nic
I noticed you have a non-CSI plenum. Be warned you need to drill a hole or something for the IAC valve. I spent 2 weeks trying to start mine without the IAC being there and unable to figure out why it didn't work....
woot finally got my tracking number for my turbo,it will be here on the 2nd so 5 more days and i should be driving upto saltlake city to pick up my fmic and cold/hotside tubbing tommorow morning
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Wow, first time I've caught up on this thread. Nice to see 3 boosted TPI cars being built at the same time!
Probably should get mine posted eventually, except it's not a thirdgen, it may not be TPI soon and I'm getting no where in a hurry with it
woot i just got back frompicking up my fmic colde side piping couplers and t bolt clamps ill post up pics in a bit
Car: 1988 Pontiac Firebird Formula
Engine: TPI 350
Transmission: Brog-warner 5 speed
Axle/Gears: Borg-Warner 9 bolt 3.45 posi
Subscribing ... i have a All forged 406 that im planning on boosting for my firebird need ideas was looking at the twin t3/t4s like you were but were told there to small so looking at the gt45 as a single cant wait to see how this turns out GOOD LUCK
the twin kit would work but yea they would be small m i was going to go with the gt45 but then i got the deal on that t6 76mm turbo so im going with that instead
I really want to see how that fits, I have the 3" version of one of those that is really undersized for what I want to do but I just didn't see how the 4" would go in the space that I have on the TA...
