More Vaccum before Boost???
Old Apr 4, 2011 | 04:14 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I just started my D1SC 383 this weekend in my 92RS. I was pulling about 12-15 PSI of VACUUM at idle. When i run it up to about 2000 RPM's the gauge pulls to about 20 PSI of VACUUM....When will it build BOOST???? I understand there is no load on the motor, its in park. I have the gauge hooked to the front vaccum port under the carb, in the same T-fitting as the surge valve (which isn't closing because the vacuum keeps increasing).
Is this normal?? And when can i expect to see the gauge actually read positive PSI (Boost)??
Old Apr 4, 2011 | 04:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: More Vaccum before Boost???
It will show boost when the throttle blades aren't a restriction.
Old Apr 4, 2011 | 04:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
just sitting in park increasing rpm by the throttle isnt gonna show any boost. go drive it, punch it, then you will see it
Old Apr 4, 2011 | 04:51 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Ok! I know a hell of alot of air was coming out of that surge valve. I just thought maybe my engine really breathes well and it wasn't gonna go into boost until a certain RPM.
Old Apr 17, 2011 | 08:43 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
OMG!!!!! I got it to go into boost yesterday on my first drive down the block. Well i now have a HUGE traction issue...If this doesnt run well into the 10's theres a problem. Now i just gotta do a little carb tweaking and get the right plugs in this motor next (time to do a search to see what everyone is using).
Old Apr 17, 2011 | 09:01 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by Slush92RS
OMG!!!!! I got it to go into boost yesterday on my first drive down the block. Well i now have a HUGE traction issue....
Nice....
$750 L98
Feb 1, 2025 02:25 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
rjcme
Sep 5, 2015 01:23 PM
