trapping mid 120's help
Old May 13, 2011 | 12:34 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
So am going to start looking into my Nitrouse system to reach my goals. Am hoping N/A she will be around 118ish. Engine specs in sig.
How big of a shot will i need? What systems do you guys recommend? I will be shooting it in second not out of the hole, i need to be easy with the rear untill the new one goes in
Old May 13, 2011 | 12:58 PM
bduffey723's Avatar
Car: not a camaro anymore
Re: trapping mid 120's help
direct port and id say about a 300 shot...
Old May 13, 2011 | 01:04 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Not answer I wanted to hear lol 300 shot for 8mph?
Old May 13, 2011 | 01:21 PM
bduffey723's Avatar
thats what i think lol
i dont have too much experience with nitrous. i ran about 2 or 3 weeks with my nitrous motor on a 500 ish shot on a WOT switch and ran a 10.3X n/a and 8.9X with the shot.
Old May 13, 2011 | 01:38 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
ill wait for someone else to chime in with an opinion lol I've seen a 2011 GT trap 118 and with a 100 shot hit 125. So other opinions are welcome! lol
Old May 13, 2011 | 03:38 PM
bduffey723's Avatar
if anything just start with a 100 and work your way up
Old May 14, 2011 | 07:41 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
This is funny...
Old May 14, 2011 | 08:38 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
with your setup now I can see you trapping around 115-120. To get into the mid 120's, a 75-100 shot would do just fine
Old May 14, 2011 | 12:06 PM
83 Crossfire TA's Avatar
I don't know why this is that hard a question, making some guesses, a 3500 car will need around 450 hp to go 118, and 540hp to go 125. In most cases when you're talking about numbers like that you're talking about NA powerbands, where you only have all the power at the peak. N2O gives you all the power at any point that you spray, so you can usually do it with a little less power then you expect, so I'd say that you'll need around 75-85hp worth of spray to do it.
Old May 26, 2011 | 12:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My 383 went 118-119 on a good day. 150 rated hit I went 128 full bottle. 4th or 5th shot on that bottle with the pressure alittle lower than I wanted, 126.xx.
Some respond better to the hit than others. 125-150 shot is all you will need and likely exceed 125mph.
its common for 11-12 second cars to pickup 10mph on a 150 shot. Some pick up as much as 15 but most I see tend to be 10-12mph or about that. Faster cars wont pick up as much. Slower cars may pick up more.
cowansauto
Apr 3, 2025 12:51 PM
LC2 TECH
South West Region
50
Jun 30, 2016 10:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
