Bottle Location
Old Jul 24, 2011 | 02:50 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Bottle Location
Guys, this might seem like a ridiculously noobish question but so far I have done little research into Nitrous because It's still a ways away from being done. I was wondering however can you mount the bottle anywhere, or does it have to be in the open for some reason? I tossed my spare tire and jack so the spare tire compartment is empty and I was thinking about hiding the bottle there for a sleeper install.
Old Jul 24, 2011 | 05:53 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Bottle Location
I am 95% sure there is no reason it should need to be in the open, should be able to put it wherever you like, as long as its not next to the engine or exhaust pipe or something silly like that. And I am pretty sure people have put them in the spare tire or rear glovebox area before.
Old Jul 24, 2011 | 06:49 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Bottle Location
just have to make certain the siphon tube is in the right location in the bottle
Old Jul 25, 2011 | 09:28 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: Bottle Location
I have mine mounted in the spare tire well. Blowout tube is routed outside of the car.
Old Jul 26, 2011 | 12:48 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Bottle Location
Hope that sucker never hits the top terminals on the battery, yikes. Mine stands up in the spare tire spot with the blowdown tube exiting the bottom of the well.
Old Jul 26, 2011 | 05:15 AM
pwdbychevy's Avatar
Re: Bottle Location
The picture doesn't show but there's 1 inch clearance between the bottle and the terminal. The terminal cover in the pic was not on all the way. Since the pic was taken I've added rubber insulation just incase the bracket decides to give way.
Old Aug 1, 2011 | 01:55 PM
Guest
Guest
Posts: n/a
Re: Bottle Location
Mins mounted wheir the rear seat pad was, right with in reach. ; ) no stupid bottle opener for me!
Old Aug 6, 2011 | 09:22 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Re: Bottle Location
I have my battery in the same spot. I will mount my bottle in the same location. I'm glad you posted a picture because I would of been too lazy to try and make it fit. Now I know it's possible. Are you using a battery holder?
Old Aug 6, 2011 | 09:33 PM
pwdbychevy's Avatar
Re: Bottle Location
Yes I am using a battery tray kit from Autozone.
Old Aug 7, 2011 | 03:20 PM
Re: Bottle Location
Really, is it the plastic black one, that costs $4.99? Do you have a picture without the bottle in place? I would like to see the mounting points for the brackets. Is your tray resting against that metal piece/bracket support?
Old Apr 24, 2012 | 03:38 PM
Re: Bottle Location
Old Apr 25, 2012 | 08:39 PM
pwdbychevy's Avatar
Re: Bottle Location
I do not have a picture without the bottle in place. The tray is bolted the bracket on the bottom and I bolted one bottle holder to the spare tire bracket and the other to the rear bracket.
Old Apr 27, 2012 | 10:28 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: Bottle Location
Here is what I did:
Old Apr 27, 2012 | 12:08 PM
Re: Bottle Location
Hey PWDBYCHEVY snap a photo for me man...
UNKNOWN_HOST that's a good setup.
Old Oct 5, 2012 | 02:58 PM
Re: Bottle Location
pwdbychevy, if you ever have your bottle out for refilling snap a photo of the mounting points for the brackets.
-Thanks
Old Oct 5, 2012 | 05:29 PM
Re: Bottle Location
Thanks, looks like one of my links died so I will post some more pics
Old Oct 5, 2012 | 05:38 PM
pwdbychevy's Avatar
Re: Bottle Location
-Thanks
Ok, im gonna weigh my bottle tomorrow to see how much is left. Ill snap one then.
Old Oct 7, 2012 | 12:45 PM
pwdbychevy's Avatar
Re: Bottle Location
Here are the pics I promised ten years ago
Old Oct 7, 2012 | 01:51 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Bottle Location
HEY. I have some rubber pad this is peel and stick. on one side, it's about 1/8 inch thick. PM me your address ill send you a chunk. and you can install it on the Bottle. (if ya like)
I use it on the inside of My battery box.as a Just in case thing.
(alum batty box) this sealed box can also be made 3" shorter in Hight.
ALL FUEL INJECTED BLOWN THROTTLE, AND THE BOTTLE!
Old Oct 11, 2012 | 11:52 PM
Re: Bottle Location
Thanks a lot!! I like how you grounded the battery to the Spare Tire Holder, ingenuity...
Is that Black Electric Tape I see on the Bottle Brackets? Appear's that one bracket only has one bolt holding it in place?
Old Oct 12, 2012 | 05:09 AM
pwdbychevy's Avatar
Re: Bottle Location
Yeah that's electrical tape. I had to modify the bracket to match the other one. The rubber coating melted off in the process of welding the bracket so I wrapped it in electrical tape for now. The front bracket is held on with one bolt. Very sturdy and the bottle doesn't move at all.
Old Oct 29, 2012 | 08:48 AM
Re: Bottle Location
Why did you have to modify one bracket to match the other? Why was modification of the bracket necessary? I see the weld, but can't figure it out...
Old Oct 29, 2012 | 08:52 AM
pwdbychevy's Avatar
Re: Bottle Location
Thats because one bracket sits higher than the other and i needed them even so the bottle could fit in the tire well.
Old Aug 11, 2013 | 11:59 PM
Re: Bottle Location
Ah Yes, Very True!!
Old Aug 12, 2013 | 01:06 PM
Ronny's Avatar
Re: Bottle Location
[IMG][/IMG]
I conceal it with a gym bag bottom of sliced lenghtwise...Stealth
Lbibb
May 5, 2016 12:00 AM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
