all done! time for tunning
Old Sep 1, 2011 | 08:23 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
all i have left to do is wire in the cutout and meth/water injection pump.
A few changes frrom the old turbo setup includes an upgrade in wastegate from 38mm to 50mm, bov was upgraded from type rs to 50mm, coldside used to be 2.5" from turbo to IC and 3" from IC to carb now its 3" all the way, turbo used to be a mpt70 now its a pt88, and dp used to be 3" now its 3.5" oh and no more 350cubes now its forged, splayed and studded 383 with 8.5:1
old setup
and the new setup
Let me know what you guys think
Old Sep 1, 2011 | 09:34 AM
Drac0nic's Avatar
Re: all done! time for tunning
Ready for some single digits is what I think. Should be fast as hell after you get her locked down, and perhaps "too much" fun
Old Sep 12, 2011 | 10:10 AM
engine bay is all done
Old Sep 12, 2011 | 01:20 PM
Ronny's Avatar
Clue me in.
I see your "valve cover breather" on pass side is routed to a catchcan with a KN breather. My breather on same passager side is the traditional(KN) type. Crankcase pressue is such that oil is leaking past the breather and drippimg on the headers. My buddy says I have signs of ring failure-blowby but I do not burn oil visually or quantity. I think the cover and breather is such that the rockers are moving oil into breather internals and it is leaking out do to its position. I see the newer GM(Proform) V covers have a flat surface on top that is parallel with ground so the breather sits perpandicular or straight up. Four sided so to speak. I may replace with that design..
What is purpose of your set up?
Old Sep 12, 2011 | 06:38 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Looks good. Only things id try and change is getting that KnN out of the engine bay. WHat kind of hood do you have? Maybe do 4inch oval tube and put the filter down with the meth tank.
Old Sep 12, 2011 | 07:02 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
looks good, that pt88 looks small in there
Old Sep 12, 2011 | 07:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Originally Posted by Ronny
Clue me in.
without baffles in the covers you will have some leaks..theres alot of oil splashing around in there. I took the baffles out of mine and started seeing oil leaking out the top.
Pt88 383 should fly! Looks great!
Old Sep 13, 2011 | 12:26 AM
83 Crossfire TA's Avatar
Does your down pipe go between the back header tube and the head? How big is your down pipe?
Old Sep 13, 2011 | 10:32 PM
Clue me in.
i mainly did it to keep the engine bay clean, i wasnt a big fan of the filters i had on the valve covers before or the chrome breathers, i think this looks better
Old Sep 13, 2011 | 10:34 PM
im not too worried about the filter its just so that i dont suck in a lil cat on the streets, the filter is right infront of one of the hood scoops, i will be running the meth kit on the streets too so that will make up for the hot air. when i had the old setup i didnt see any gains by taking the filter off. I have a 2 inch ram air hood i would not be able to fit a pipe between the upper radiator support and hood since the hood rests on it.
Old Sep 13, 2011 | 10:35 PM
thats what im hoping...
Old Sep 13, 2011 | 10:40 PM
here is a pic i took some time ago, its a 3.5" dp
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
