Welded Manifolds- how fast
Old Sep 1, 2011 | 10:54 PM
83 Crossfire TA's Avatar
I know that there are a few people here (and in other places) that have run turbo flanges welded to stock exhaust manifolds.
  • How fast have people gone with them?
  • How fast do you think you can go?
  • Where did you put the wastegate flange?
(I just had a nutty idea that I just might try...)
Old Sep 1, 2011 | 11:26 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: Welded Manifolds- how fast
One look at stock Syclone/Typhoon turbo plumbing and your mind will be put at ease. That said, I don't know any real world numbers that people have achieved with such things. My opinion is that using a decent design stock manifold and good flange fabrication would support around 600 hp.
Old Sep 2, 2011 | 05:33 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 83 Crossfire TA
I know that there are a few people here (and in other places) that have run turbo flanges welded to stock exhaust manifolds....
That is essentially what the Gale Banks kit is, there is nothing really special about the exhaust manifolds that his kit employs, and they've been brought to well over 1000 horsepower for years....
http://www.youtube.com/watch?v=p4DLnBR1JjQ
Old Sep 4, 2011 | 08:11 AM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Flipped factory corvette headers, no definitive numbers because I'm still tuning but I've maxed out the 36lb injectors at just under 10# boost and there is easily more in the combo. That'll be it for the season since the car leans 10degrees to the right and has a bent and cracked frame, nothing I did One day soon I'll get off my lazy *** and start a thread on the build.
Old Sep 4, 2011 | 03:08 PM
What's wrong with the sy/ty setup? it's a bit hard to work around but the plumbing is actually pretty decent and flows OK...
Old Sep 4, 2011 | 06:46 PM
Drac0nic's Avatar
Just throwing this out there, not all manifolds are created equally so be careful which ones you use. I would start out with something like the Vortec 350 (I'm wanting to say that's what they are) as the ports are HUGE compared to the other set I have here.
Old Sep 8, 2011 | 08:24 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
3650lb, 108mph, 15%loss => 440BHP
modified TPI exh manifolds, worn 355ci, 882 heads, 216/216 cam, LT1 intake, no IC, no water/alky, 10 PSI, twin T3-.63A/R - 60 trim CW
Biggest problem it has is the worn rings & bores wanting to cause detonation when a normal amount of boost timing is run. I think with good sealing there is another 30HP in it. With an IC or water/alky add another 30HP. In the end, I would say maxed out it could make 600HP with more boost. The complete combo was built based on maxing out at 600BHP.
internal wastegates in the turbine
For the amount of time it takes to make the manifolds I would try it. If they didn't make the HP you want then sell them local or ebay. You really can't lose.
Old Sep 9, 2011 | 12:15 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Nothing wrong.. that was my point, it works great but the crossover is tiny.. and those trucks have gone pretty fast on stock plumbing.
Old Sep 9, 2011 | 12:30 AM
Heh... heading out to the garage to look at something...
Old Sep 13, 2011 | 12:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
what are the GN guys running?
InfernalVortex
Apr 20, 2021 11:31 AM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
