TURBO!!!!!!!!
Old Sep 26, 2011 | 11:17 PM
birdman8992's Avatar
Car: 92 Pontiac Firebird
Engine: 350 small block
Axle/Gears: stock
TURBO!!!!!!!!
Okay i have a question I have a 350 which was board .40 over and stroked to a 383. i am wanting to see if i was able to go turbo and if so what would be a good simple set up and how much would i be looking at?
also i seen this turbo kit on ebay is this worth it or just plain trash?
http://cgi.ebay.com/ebaymotors/UNIVE...item2a143ec73e
Old Sep 27, 2011 | 12:10 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: TURBO!!!!!!!!
As far as most are concerned there really isn't a full turbo kit which is usually true. As far as buy turbo "kits" from eBay its hit or miss. You can use some of the stuff but not all. There's people on TGO that have eBay items and are happy with them. Personally I can't say much on the kit bc I'm still currently putting my car together but. Is just be careful
Old Sep 27, 2011 | 01:00 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: TURBO!!!!!!!!
THE GT45 TURBO is heavy but does work.....im running one temporarily untill i get my master power t76 rebuilt..so far i hsve no complaints on the turbo.
Old Sep 29, 2011 | 02:24 AM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
Re: TURBO!!!!!!!!
I don't think there is a HEADER manifold in that kit!
NEVER USE EBAY OIL LINE KITS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! trust me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
keep looking. I have ebay turbo, blow off, wastegate, Intercooler and they are working good for me.
Old Nov 19, 2011 | 01:32 AM
91kbell's Avatar
Re: TURBO!!!!!!!!
Sorry to dig up an old thread but why do you say not to
Use the eBay kits?
Old Nov 20, 2011 | 02:20 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: TURBO!!!!!!!!
Poor Quality for the most part. Some people have had some luck.
Old Nov 20, 2011 | 11:19 AM
project89's Avatar
Re: TURBO!!!!!!!!
ive used,installed tons of ebay turbo stuff, never had an issues except for one turbo that blew an oil seal, but it was my fault since i forgot to add a restrictor in the line, since my car made over 100psi of oilpresure at redline \even a name brand turbo would have blown out the seal.
#1 does ebay stuff work - yes
#2 is it as good as name brand stuff -no
as stated above though do not use the ebay oil feed and return lines they flat out suck and will leak or break
ebay blow off valves stay away fromt he greddy rs or type r style valves they leak, stick with an ebay rfl style bov,blitz style , or the tial style valves, i hear the ebay hks ssqv valves arent bad but i havent persoanly used them.
ive never had an issue with the ebay wastegates either
ebay intercollers both air to air and water to air work great
the tbolt clamps that come with ebay kits will snap the bolts if u over tighten them so dont over tightnen them
Old Nov 20, 2011 | 06:30 PM
91kbell's Avatar
Re: TURBO!!!!!!!!
Thanks for the heads up guys, I already have my hotside done so I wasn't considering the headers, just the other misc. Stuff. Where would you recommend getting the oil lines at then?
Old Nov 22, 2011 | 01:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TURBO!!!!!!!!
Curious if anyone could get this kit to fit
http://wrenchrat.com/twinturbo/
Probably need to ditch power steering and possibly do something about the big brake booster/master combo...it would be a tight squeeze on drivers side for sure.
Old Nov 23, 2011 | 11:09 AM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
Re: TURBO!!!!!!!!
theirs some pretty serious builds using the gt45 on the turbo forum. haven't really heard much bad about them. might want to check out those forums as well. i'm going with a gt45 for my build I'm doing. check out this guys build http://www.forabodiesonly.com/mopar/...116512&page=40
he has twin gt45's and wow just wow he also has a some vids in that thread of a few different cars running 8's on ebay gt45's.
Old Feb 7, 2012 | 04:59 PM
PNYKILR's Avatar
Engine: twin turbo dart 406
Re: TURBO!!!!!!!!
power steering will fit with the march kit. With the brake booster pushing the master cylinder out so far, the lines are about a 1/4 away from the header. I got rid of my booster and there is lots of room. If your going to spend the big money for this kit, you are better off getting it custom made. Welds suck, its too difficult to take off valve covers, and it would be nice to run 4" exhaust instead of 3". I heavily modified the headers moving them away from the valve covers and re routing the waste gate pipe, dumping it to atmosphere.
Old Feb 10, 2012 | 08:49 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: TURBO!!!!!!!!
Did that $5000 even include the intercooler?
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
