pics of a turbo project
Old Oct 23, 2011 | 06:33 AM
turbotater's Avatar
Old Oct 23, 2011 | 07:03 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
Re: pics of a turbo project
i like it. keep the pics coming
Old Feb 22, 2012 | 05:15 AM
turbotater's Avatar
Old Feb 22, 2012 | 05:17 AM
turbotater's Avatar
the alternator and power steering still fit a just have them off to make multiple test fits faster.
Old Feb 23, 2012 | 11:32 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
WOW very nice!
Old Apr 30, 2012 | 09:10 PM
turbotater's Avatar
latest pics
Old Apr 30, 2012 | 09:12 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Very nice, it reminds me of Rick Heads old setup...
Old Apr 30, 2012 | 10:27 PM
Adamsapple's Avatar
Car: 1989 Firebird
Engine: 5.7 Lit. V8
Nicely done
Old May 1, 2012 | 03:52 PM
TwinTurboROC's Avatar
Nice, ebay turbos? What you doing about the rad/fan combo because it looks really close.
Old May 1, 2012 | 05:47 PM
turbotater's Avatar
there is about 2" clearance to exhaust housing. the wastegate top is 1/2"
away but it should not generate as much heat.
the turbos are the ebay 57mm stage 3 turbine.
Old May 4, 2012 | 11:08 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Hey what kind of carb hat do you have?
Old May 5, 2012 | 06:26 AM
turbotater's Avatar
csu
Old May 5, 2012 | 04:54 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
I love the placement of those turbos!!!
Very smart!!!
Where did you get the headers???
Can't wait to see what it does
Old May 5, 2012 | 09:18 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I like the twin turbos, but I'm not feeling the early Superman colour scheme.
Old May 6, 2012 | 04:06 AM
i do believe those are the SSautochrome ebay ones, and he modified the passenger side to accomidate the ac. correct tater? and that is the most gansta' color scheme ever...i love it...then i hate it...then i love it again.
Old May 6, 2012 | 07:20 AM
turbotater's Avatar
about that color ...
it is not staying. the guy that owns the car painted it
before i got involved. probably be some silver/grey
variant to compliment the body color.
the headers are the ebay pieces i cut both collectors off
changing the angle on the driverside and moving the
collector on the passenger side a few inches up and over.
the #7 primary tube hits the steering column so i still
have to cut it up and move it. I do not reccomend these
headers. the owner of the car bought them and i said i
could make them work.
thanxs for the compliments
Old Apr 11, 2013 | 01:29 PM
turbotater's Avatar
I have redone alot on this project and I am making headway again.
IMG]http://i3.photobucket.com/albums/y97/turbotater/garys%201983%20firebird/IMG_0135.jpg[/IMG]
Old Apr 11, 2013 | 01:31 PM
turbotater's Avatar
missed the gauges
Old Apr 11, 2013 | 01:49 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
wow impressive!!!!
Old Apr 11, 2013 | 05:00 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
That turbo looks familiar. What the full specs
BTW the placement on those turbos looks amazing. I like it!
Old Apr 11, 2013 | 06:12 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Very nice! Share the cam specs and what you expect HP wise? Thx!
Old Apr 11, 2013 | 06:25 PM
turbotater's Avatar
this engine is just the basic midly warmed over 355 right now.
It should make 400 rwhp with this setup.
The turbos can support 600 or more rwhp with different heads , cam and intake.
All the supporting stuff is there fuel pump , ignition , exhaust etc for future mods.
Old Apr 11, 2013 | 07:13 PM
project89's Avatar
if those are the 57mm units 57mm inducer 76mm exducer on the cold side they will do well over 400rwhp
as a pair they should be capable of more like 7-800 rwhp and close to 4 digit hp at the crank
all depends on which turbine wheels and housings u have
Old Apr 11, 2013 | 07:25 PM
fasteddi's Avatar
Car: 1991 Camaro RS
What about the turbine side?? a/r..exc
Old Apr 11, 2013 | 08:26 PM
turbotater's Avatar
turbine side
major = 2.790"
minor = 2.435"
.68 AR T3 housing
Old Apr 11, 2013 | 08:27 PM
fasteddi's Avatar
Car: 1991 Camaro RS
thats pretty close to mine. Nice build BTW
Old Apr 11, 2013 | 08:34 PM
project89's Avatar
turbine side
major = 2.790"
minor = 2.435"
.68 AR T3 housing
a tad smaller then the ones im using but u should have no problems getting 750 out of what u have now when u turn the boost up
is that a dual plane manifold i see on that engine ?
Old Apr 11, 2013 | 08:49 PM
turbotater's Avatar
yea it has a dual plane intake on it right now, low boost should minimize distribution issues. like I said it is a pretty mild engine right now and I am only shooting for 400 rwhp for now. maybe do a head intake cam swap this next winter.
Old Apr 12, 2013 | 02:56 AM
project89's Avatar
what heads are on it now ?
Old Apr 12, 2013 | 04:18 AM
turbotater's Avatar
just some TBI heads from '89
I figure the motor probably makes 250 rwhp
Old Apr 12, 2013 | 06:28 AM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
On your steering shaft, use the Jeep steering shaft upgrade. Its much thinner with no rag joint or huge plastic cover and helps a lot.
Old Apr 12, 2013 | 07:58 AM
turbotater's Avatar
not familiar with this steering shaft upgrade. more info please.
I have already cut the offending primary tube and moved it out the way for this application but I would be interested for future stuff
Old Apr 13, 2013 | 08:36 PM
turbotater's Avatar
new picks
Old Apr 13, 2013 | 08:48 PM
Kingsobieski's Avatar
Aw I liked the pontiac blue.
Old Apr 14, 2013 | 04:33 AM
turbotater's Avatar
how bout some background color for the gauges?
click on pic
Old Apr 14, 2013 | 07:11 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Wow. Thats going to be a sweet setup when its done. I want to remake my headers and have the turbos in a similar spot. Btw where did you find that intercooler at?
Old Apr 14, 2013 | 08:25 AM
turbotater's Avatar
modified godspeed unit on the intercooler
thanxs for the replys
Old Apr 14, 2013 | 08:47 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Very nice clean setup you have going there.
Old Apr 14, 2013 | 09:59 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Looks great! Can't wait to see it finished!!
Old Apr 27, 2013 | 03:23 PM
turbotater's Avatar
the 3" down pipes are done. they go over the trans cross member and will tie into the 4" exhaust
Old Apr 27, 2013 | 03:37 PM
turbotater's Avatar
more pics
merge
passenger side
drivers side
distance below front cross member
Old Apr 28, 2013 | 08:32 PM
  #42
Very nice work...
Old May 9, 2013 | 05:27 PM
  #43
turbotater's Avatar
latest pics
Old May 9, 2013 | 09:29 PM
  #44
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Had to put on my sunglasses to see the pics!
Nice!
Old Jun 11, 2013 | 07:20 PM
  #45
turbotater's Avatar
Re: pics of a turbo project ( it lives 6/11/13 )
finally after what seems like an eternity we were able to start the engine. there were a few leaks on the checkout stage as usual with a complete build. then after loading a timing map in the msd and setting base timing we hit the key and magic happened, IT STARTED.
I have built a lot of cars over the years but i was so glad this one fired up and sounded good.
Anyway here are a couple of the latest pics.
Old Jun 11, 2013 | 07:23 PM
  #46
looking good man
Old Jun 28, 2013 | 05:57 PM
  #47
turbotater's Avatar
I have been slowed up a bit fighting clutch / trans problems. The biggest problem being to much run out at the transmission flange . I welded and filed the dowel pin holes and corrected that and now I can shift gears ( still have not drove it yet) .
Little by Little .
Old Jul 2, 2013 | 07:30 PM
  #48
angermk3's Avatar
Car: 1987 Iroc - Z
Transmission: t-5
sub'd
Old Jul 2, 2013 | 07:56 PM
  #49
Psychoz28's Avatar
Car: 1984 Z28 / 2002 Z06
Engine: 350 New Crate / LS6
Transmission: T5 / M12
Axle/Gears: 3.73 / 3.42
Wow ... Love this engine! Good looking with these lil monsters on each side!
Old Jul 3, 2013 | 02:44 PM
  #50
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Looks great.
Is that 308 filler rod you used to attach pipe to the passenger side header? Is that 304 pipe you added?
