pics of a turbo project
Old Jul 3, 2013 | 07:23 PM
  #51
turbotater's Avatar
Re: pics of a turbo project
yep 308 rod. i was told go up one grade from the stainless you are welding.
Old Jul 3, 2013 | 08:32 PM
  #52
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Got chrome? Nice build man.
Old Nov 18, 2013 | 06:05 AM
  #53
turbotater's Avatar
just thought i would post a couple more pics after i started driving it.
Old Nov 18, 2013 | 07:03 AM
  #54
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Looks nice.
What does one do if he wants to have a hood ?
-- Joe
Old Nov 18, 2013 | 07:11 AM
  #55
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Great job on the exhaust fab... that looks great...
A couple suggestions from working with the pipes on the cold side....
You can cut the radiator support and lower it down 2-3" to give you room to put the
main cold pipe right into the actual upper core support. It would hide it and you could color match as well. (See pic of my old setup)
Then where you have the air cleaners... Take some pipe and put both of the air filters down under the body where the stock battery would be (On both sides) That way your pulling cold air not 200Deg engine heat. It will make your intercooler work much better!
You have great fab skills for sure!
~Scott
(Dropped radiator and pipes through core support)
Old Nov 18, 2013 | 08:17 AM
  #56
turbotater's Avatar
Thanxs for the compliment
The car has a hood. I used flush mount hood latches in the front corners.
Old Nov 18, 2013 | 08:25 AM
  #57
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
No kidding? So that 3" pipe tucks between the hood and radiator support without issue? Stock type hood ?
-- Joe
Old Nov 18, 2013 | 08:34 AM
  #58
turbotater's Avatar
Here is an interior shot. It has led interior lights and back lit gages that are adjustable in intensity and color.
Old Nov 18, 2013 | 08:37 AM
  #59
turbotater's Avatar
Yep. It has a " formula" type hood and it clears.
Old Nov 18, 2013 | 03:30 PM
  #60
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
Looks really good. Did you fab everything yourself? I'm looking at doing a single maybe twin here in the near future. And info on where you bought supplies or parts would be great.
Thanks.
Keith
Old Nov 19, 2013 | 04:20 AM
  #61
turbotater's Avatar
yep all work done at my house by me and a couple of friends.
any questions just ask.
Old Nov 19, 2013 | 09:58 AM
  #62
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Could you post a pic from the front, did you rework the front grill for the IC? Excellent job!
Old Nov 19, 2013 | 10:32 AM
  #63
turbotater's Avatar
I did not have to modify the bumper. Just make mounts behind the bumper and before the radiator support. The 1983 cars have openings in the bumper cover and work well at getting airflow into the intercooler.
Old Nov 19, 2013 | 10:46 AM
  #64
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Wow, awesome fab! Subscribed for the updates!
Old Nov 19, 2013 | 01:10 PM
  #65
KBD85's Avatar
Car: 1985 trans am
oh man!!! i realy want one!! very nice build!
Old Nov 19, 2013 | 02:49 PM
  #66
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
turbine side
major = 2.790"
minor = 2.435"
.68 AR T3 housing
It looks great. Got a link to where to buy that turbo? The 57 trims I saw on ebay have a smaller wheel.
Old Nov 23, 2013 | 06:02 PM
  #67
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
what kind of MSD system did you go with?
Old Nov 26, 2013 | 06:30 AM
  #68
turbotater's Avatar
msd6530
i have used this box a couple of times and if you have a carb it is the only way to go. least expensive way to get good spool and driveability as well as power
Old Nov 30, 2013 | 02:51 PM
  #69
formulakeith's Avatar
Car: subaru wagon, two formula's
Engine: tpi 350's
Transmission: 700 r4
Axle/Gears: 3.27 posi
How has this project been? Been a while since anyone posted about it, I'm about to do a twin turbo project on my formula, but will be a little different. Looks very nice
Old Dec 1, 2013 | 10:09 PM
  #70
Engine: tpi 350's
I'm almost going to buy that twin kit on ebay with the same headers as the stock ones you have, I'm just concerned that it won't clear the factory belt setup and the driver side turbo will be offly close to the radiator hose, but my radiator fits under a stock style hold down. SO IDK, then my p/s hoses will be offly close to the turbo too on driver side, did you have issues with that?
Old Dec 2, 2013 | 06:50 AM
  #71
turbotater's Avatar
i would not buy these headers again , i would not use them if they paid me.
no way will they work as delivered with TPI serpentine brackets and a decent exhaust system. I cut the collectors on both just repositioning the drivers side, i cut off the passenger side collector completely off /cut the primary tubes/rewelded the collector back on/added tubing to the collector to clear the A/C then welded the flange back on. then i cut the number 7 cylinder primary tube and moved it to clear the steering shaft. what i ended up with is a good looking set of headers that i can change plugs on six cylinders from underneath with minimal effort using my lift and two cylinders that cause me to utter bad words. there is no way i would even attempt to try and pull a plug at the track.
now if the downpipes just dumped down that would allow better plug access but the headers would still require mods to work with the factory TPI brackets and clearance of the steering shaft are still would need to be done.
Old Apr 25, 2014 | 02:54 PM
  #72
turbotater's Avatar
update time :
Well I was disapointed in the performance of the engine so I put some 062 vortec heads on it , an air gap intake and a 10 year old cam I had done for some small twin turbos.
Now it runs like it should . I was initially lean under boost so I made some major changes to the carb, smaller HSAB's , opened up the PVRC's some more and upped the jetting.WOT A/F is now at 11:3 so I am in the ballpark there, it is a little rich under cruise at mid 13:1 but my part throttle acceleration is pig rich in the 10:1 range. So I will go to a later opening power valve and probably down a little in jetting.
It is fun just putting it in second gear and mashing the throttle and when the turbos start making boost the tach swings to 6000 rpm and tire are up in smoke
Old Aug 11, 2014 | 04:26 AM
  #73
Engine: tpi 350's
I am going to start my project probably next week, I gotta figure out how to put pics up on here, I have all the parts for it, I just have to start setting it up, weld downpipes, hook up oil lines, then turbo lines, should be fun!
Old Aug 12, 2014 | 01:22 PM
  #74
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
update time :
I know you haven't posted on this in a while, but how did it run with the old TBI heads vs the Vortecs? Did you make it to the track? And how much boost are you running? Your work looks great.
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
Wife'sCar
Sep 5, 2015 08:58 AM
tonys91rs
Sep 2, 2015 07:07 PM
