Lets see those BLOWERS and PROCHARGERS!!!
Old May 30, 2012 | 03:56 AM
  #151
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
Re: Lets see those BLOWERS and PROCHARGERS!!!
Originally Posted by patin88z
Just doing some moch up.....for now.
Nice! What Numbers Are You Pulling Off? Do You Have Any Internals Or Is It All Stock Besides The Your Procharger?
Old May 30, 2012 | 05:58 PM
  #152
Guest
Guest
Posts: n/a
No numbers, only very little progress on the build....blower is still sitting on the same bench needing a full rebuild. Ill be rebuilding it myself and diving back in the build after I get threw working on my house and moving into it.
Old Oct 15, 2012 | 10:57 PM
  #153
Guest
Guest
Posts: n/a
update: $21xx to finish the blower build.
Old Oct 24, 2012 | 06:26 PM
  #154
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
I will have numbers hopefully tomorrow. my car keeps going on back lag, but it runs now so it should be quick.
Old Oct 24, 2012 | 09:22 PM
  #155
Guest
Guest
Posts: n/a
After much thought and calculating...iv decided to let Procharger rebuild my blower....
-bearing and seal kit $500
-2-3 ton press $175-250 ish range
-800-900 for a full rebuild
Old Oct 27, 2012 | 10:01 PM
  #156
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Not all done yet but its coming along, I also bought a WM set up for it to keep the detonation down and it will help raise the octane level on pump gas.
Attached Thumbnails Lets see those BLOWERS and PROCHARGERS!!!-img00040-20111201-1914-800x600   Lets see those BLOWERS and PROCHARGERS!!!-101_0446-1280x960-.jpg   Lets see those BLOWERS and PROCHARGERS!!!-101_0448-1280x960-.jpg
Old Nov 10, 2012 | 09:27 AM
  #157
Guest
Guest
Posts: n/a
TPI CARS: what blower pulley are you using and what PSI is it netting you?
Old Nov 10, 2012 | 09:56 AM
  #158
Guest
Guest
Posts: n/a
*TPI cars with D series blowers*
Old Nov 12, 2012 | 10:02 PM
  #159
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
Originally Posted by Twin_Turbo
DAMN
sleprock
Oct 1, 2015 09:39 AM
86IROC112
Sep 28, 2015 08:17 PM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
buckeyecelt
Sep 24, 2015 05:50 AM
