Fuel system diagram
Old Dec 6, 2011 | 02:21 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Fuel system diagram
Im trying to put together a fuel system for my car, but Im struggling to find a diagram to show a layout of the components. There seems to be several different ways of doing it.
Im using an Aeromotive Eliminator pump, -10AN line and a Holley 700DP carb.
Im thinking of using an Aeromotive 13202 regulator
Old Dec 6, 2011 | 04:23 PM
DIGGLER's Avatar
Re: Fuel system diagram
i believe there is a diagram on the aeromotive website.
Old Dec 7, 2011 | 03:13 PM
Car: '92 RS Camaro
Transmission: TH400
There are several, but they are not clear on carb connections, and I dont know which layout would be best? Thanks for the reply
Old Dec 7, 2011 | 04:12 PM
bonesbrakr's Avatar
Quick rundown
Gas comes out of tank and to pre filter
From pre filter into fuel pump
From fuel pump into a second filter
From Second filter to input of regulator
Output of regulator goes to carb
Return line from regulator goes back to gas tank
Hope that helps.....
Old Dec 11, 2011 | 07:39 AM
Car: '92 RS Camaro
Transmission: TH400
Ive just added up the cost of all the fittings, hose, regulator etc, and it comes to an eyewatering $900! That includes shipping and tax. I already have the pump. Going fast isnt cheap
Old Dec 11, 2011 | 12:59 PM
DIGGLER's Avatar
boy your not kidding.... after doing my fuel system and changing stuff around 3-4 times, i have a drawer full of AN fittings and hose i am not using. pretty sure there is well over $500 sitting in that drawer.
Old Dec 11, 2011 | 01:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I "believe" I have $1300 into my fuel system in fittings/lines/regulators not counting the pump that was $520
Going fast isn't cheap
Old Dec 11, 2011 | 03:38 PM
Car: '92 RS Camaro
Transmission: TH400
It sounds like your unused stuff would be better on my car If any of its for sale, I would definitely be interested. Its mainly -10 AN stuff I need.
Old Dec 11, 2011 | 11:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yeah fuel systems never are cheap when you need flow for big power. I got a bunch into mine and its not going to be enough for the new motor.
You running a sumped tank or a fuel cell or what? Is your motor a blown 406 listed in your information?
Old Dec 12, 2011 | 02:24 AM
Car: '92 RS Camaro
Transmission: TH400
Yes it is the same motor, a D1SC Procharger on a 406. Its got AFR 210 heads, Dart block, JE pistons etc, so built for big power. Im using an Aeromotive Eliminator pump, so will certainly be sumping the tank. Because I'm want to use -10 AN line, all the fittings, filters, regulator etc. add up to a lot. I looked into going the dual in-tank route, but I cant see it being any cheaper.
Old Dec 12, 2011 | 09:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I have a dual intank kit. twin walbro 255 pumps, -8an teflon lined braided hose feeding my rails, with Fuel lab filter and Fuel Lab regulator, with -6an teflon lined braided hose for return. All the fittings and pump assembly cost me over 1700 Included wiring harness and hobbs pressure switch to activate the secondary pump.
Should be good to 1000hp tho and I will be testing that.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
jahblah
Aug 12, 2015 05:54 PM
