Blower Cam
Old Dec 21, 2011 | 02:15 PM
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Blower Cam
I thinking about putting in a better cam this winter for my procharged motor. I called comp cams and they recommended 240/248 duration and 536/536 lift on a LSA 114. I have 1.5 roller rockers and I'm thinking I could go to the 1.6 to get a little more lift. What do you guys think about this cam or what else would you run.
Old Dec 21, 2011 | 02:17 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Blower Cam
Originally Posted by Eric89sc
I thinking about putting in a better cam this winter for my procharged motor. I called comp cams and they recommended 240/248 duration and 536/536 lift on a LSA 114. I have 1.5 roller rockers and I'm thinking I could go to the 1.6 to get a little more lift. What do you guys think about this cam or what else would you run...
What is your entire setup, and what are your horsepower goals...?
Old Dec 21, 2011 | 05:04 PM
Eric89sc's Avatar
Car: 1989 camaro
Re: Blower Cam
OK so where to start.
Its a 010 four bolt block bored 40 over, steel crank and pink rods with forged pistons.
I have the 230cc, 64cc chamber iron eagle platinum heads on with 9.6.1 compression.
It has edelbrock victor Jr intake with a 850 carb by CSU on.
I have a F1A procharger with 20 pounds of boost for now...
I am running on 94 octane with methanol injection kit, 3 nozzle kit.
Old Dec 26, 2011 | 02:10 PM
Eric89sc's Avatar
Car: 1989 camaro
Re: Blower Cam
Any one have any suggestions?
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
