Hood height needed for EV Pro Carb Hat
Old Jan 20, 2012 | 11:51 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Have done several searches and can't seem to find an answer. Getting ready to put a new blow through 383 motor in the camaro. The EV standard hat is 4" high and the Pro is 5". There is a SS fiberglass hood on the car. Appears to have 3" more clearance than a stock hood where the hat will mount.
It calculates that the 4" may fit but the 5" won't. (Performer RPM Air Gap, 4150 Blow through carb)
Those of you running hats, what size hood did you have to use to clear your hat and what is the height of your hat. Thanks in advance.
Old Jan 20, 2012 | 02:08 PM
Ronny's Avatar
Re: Hood height needed for EV Pro Carb Hat
I bought a 2.00 inch carb hat on ebay a while back (84 Vette with 7.4L TBI)).
Old Jan 20, 2012 | 06:49 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Smaller hat is not an option on this motor. Thanks anyway.
Old Jan 23, 2012 | 09:53 AM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
I have a 4" fiberglass cowl hood, with a procharger competition hat (I believe it is 4" tall) and 1" spacer that fits.
Attached Thumbnails Hood height needed for EV Pro Carb Hat-mount-pleasant-20120122-00172.jpg   Hood height needed for EV Pro Carb Hat-mount-pleasant-20111006-00023.jpg
Old Jan 24, 2012 | 11:51 AM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
IMHO, that one inch smaller four inch hat isn't gonna be a restriction if you're still trying to blow through a dual plane.
Single plane would prolly help out alot.
I fit a Super Victor, Holley, and cheapo restrictive Spectre hat under a three inch cowl.
Could prolly fit a four inch hat with a four inch cowl if need be.
Old Jan 24, 2012 | 12:00 PM
Car: 88 GTA, 74 T/A
The dual plane is coming off, I have a victor jr that will be going on shortly.
Old Jan 24, 2012 | 12:05 PM
Ronny's Avatar
Funny they polish the outside when it may be more benefical to polish the inside!
Old Jan 24, 2012 | 01:08 PM
Car: 85 Berlinetta
Peformer RPM is a wonderful N/A piece, but the Jr. will be much better boosted!
Old Jan 24, 2012 | 01:15 PM
Car: 88 GTA, 74 T/A
The dual plane is a good street intake, good low end power, but everyone I talked to suggested going to single plane. Getting ready to change ignition boxes as well. I currently have a crane hi6 box, but I going to get a MSD boost referenced box that will automatically kick the timing down once the boost is applied. (just a side note I just put on a D1SC procharger this winter, getting close to getting it up and running.)
Old Jan 24, 2012 | 01:22 PM
Car: 85 Berlinetta
MSD 6530 is a great choice!
Old Jan 24, 2012 | 01:25 PM
Car: 88 GTA, 74 T/A
I was thinking more along the lines of MSD 6462.
Old Jan 24, 2012 | 02:00 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
You will gain very little with the vic jr. Some hp at higher rpm around 6500 on most stuff. Blow thru on the engine dyno showed better mid range torque with the RPM Performer and almost equal at 6200. (6hp )
The 5" hat showed 11-15 hp more than the 4". This is on a 650 hp motor with 10lbs boost.
I am trying to fit the 5" but won't cry if I can't. This is strictly a strip car.
I run the HI 6R with a boost retard. It seemed more stable and repeated better than the MSD stuff.
Thanks for the help.
Old Jan 24, 2012 | 02:06 PM
Car: 88 GTA, 74 T/A
A lot of varibles that can come in to play here as well, compression, cam, heads etc. Sounds like like you found a combination that works well with a dual plane set up as well.
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Exxon Limited
Aug 9, 2015 08:13 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
