maf to map
Old Feb 14, 2012 | 03:43 PM
stephennmm's Avatar
Car: 85 firebird
Engine: 4.8 lsx
Transmission: th400
Axle/Gears: 8.8 ford 3.08
maf to map
Im new to the tpi on these cars but am familiar with other fuel injections. What im trying to find is how you guys are swapping to a map from maf without a aftermarket ecu??? I am wanting to turbo the car in the future but right now just getting it dependable and swapping a t56 in. Thanks Stephen
Old Feb 14, 2012 | 03:46 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: maf to map
Your 1985 has just about the worst computer GM ever put in a Camaro. You can install a 1990-1992 TPI Camaro computer along with a "chip from a GM Syclone" derivative. The wiring harness would need to be modified a little and the ECM connector needs some wires moved around.
Old Feb 15, 2012 | 03:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: maf to map
Yep, exactly what I did. 89 MAF to 91-92 MAP ecm. Kept my wiring harness but repinned to the back of the 91-92 ecm. Need an extra connector for the ECM since 91-92 uses 3 while 86-89 maf uses 2. It was pretty easy and straight forward but kinda a PITA to bend over plugging and unplugging wires into the ecm.
Had to take the MAF wiring out and put in MAP sensor wires and run to the ECM thru the firewall. Not hard to do but depends on where you put things.
Old Feb 15, 2012 | 03:35 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: maf to map
You can use the MAF wires for the MAP sensor. No need to remove and install new wires.
Old Feb 15, 2012 | 03:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: maf to map
Yeah true you could reuse that wiring. I mounted my map half the distance from the original MAF so I still needed to pull those wires back down the harness to clean it all up. Just have to unpin the MAF wires and move to the right spot on the 730 ecm
Old Feb 15, 2012 | 09:52 PM
stephennmm's Avatar
Car: 85 firebird
Engine: 4.8 lsx
Transmission: th400
Re: maf to map
ok so let me see if i have this right. I can reuse my harness i just have to swap the computer and swap 2 pins in my harness???
Old Feb 15, 2012 | 11:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: maf to map
Theres a swap article here, but theres a few more than just a few pins.
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Old Feb 23, 2012 | 11:31 PM
stephennmm's Avatar
Car: 85 firebird
Engine: 4.8 lsx
Transmission: th400
Re: maf to map
Has anyone tried the converter boxes for $300. I dyno shop told me about them instead of doing the wiring and all anyfeedback???
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
