305 lgh quadrajet 4bbl super charger?
Old Mar 14, 2012 | 07:23 PM
c.johnson8907's Avatar
can i get a super charger to fit/work with my lg4 305 and quadrajet 4bl?
Old Mar 14, 2012 | 07:31 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 305 lgh quadrajet 4bbl super charger?
Originally Posted by c.johnson8907
can i get a super charger to fit/work with my lg4 305 and quadrajet 4bl?p
Yes, blowthru quadrajets are very easy, you need to drill and lock the secondary flapper with a set screw on the bottom if your going to run a carb hat. The choke is not effected either way, so do not mill it off. Just tune your fueling properly with the right rods, boost referenced fuel pump, etc. I believe Vortech sells a universal system that is cheaper than the Prochargers that you can adapt to your setup, you will just need to fabricate the charge pipes and do your own Intercooler...
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Thaney9
Aug 29, 2015 03:16 PM
86IROC112
Aug 17, 2015 02:00 PM
