383 125 shot idea need help
Old Jul 26, 2012 | 06:41 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Axle/Gears: 10 bolt posi 3.08 gears
Well thinkin bout findin a cheap budget camaro most likely a v6 with a stick takin out driveline and dropping in a built 383 forged bottom end makin hopefully 450hp then putting a 125 shot just for some extra ump lol done some reading heard u gotta get a timing controller and a electric fuel pump but I need more details of exactly what I need to do oh and a rev limiter what kind of compression,should I look for wanna run,pump gas car is gonna be mostly for cruising around maybe a little racing know theres a mustang and a honda waiting to get stomped plan on running a t56 behind it also car is going to be carbed ive also heard bout getting a cam made specifically for nitrous something bout more exhaust lift and duration any help would be great first time with nitrous starting small I know nitrous is dangerous if not done properly and my motor and money will go boom also ive heard bout building the motor as if it were making the power it will be with nitrous as if it was n/a just for extra insurance
Old Jul 30, 2012 | 10:30 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 125 shot idea need help
Carbed, just run whatever size fuel pump that is needed for the hp range you plan to run. that would likely be 450+125
Kit would just be a simple plate type kit jetted for 125 shot...many manufacturers have this available, just choose one.
Now I'd recommend an aftermarket ignition box...MSD or Mallory type that has a built in timing retard function for nitrous use. I'd tune the motor first, find what timing is best...say 36 deg. Then for the 125 shot I'd try 30-31 deg timing...so on the box, set it to pull 5-6 deg and use that as a baseline starting point. It may want more timing it may want less.
Now the nitrous system is going to be triggered most likely by a WOT switch on the throttlebody. There are other ways to do it but this is how I'd do it for simplicity sake. The timing retard function will be wired into the WOT switch so when you go WOT, the nitrous solenoids will be activated, and so will the timing retard function.
The nitrous master arm switch will provide the 12 volts for the system. This way, when nitrous is turned off, the ignition advance will remain 36 deg full timing for all motor performance, and when nitrous is on, you will be safe on timing.
For a mild street 383, I'd shoot for 10-10.5 to 1 comp with aluminum heads... 9-9.5 with iron and let it eat. Run a step colder spark plug, likely heat range 6 or 7 for that motor with a 125 shot.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
fasteddi
Sep 2, 2015 10:29 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
