Feeding fuel to a 406 w/ S372 turbo...
Old Oct 21, 2012 | 01:18 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
I am researching the possibility of using this Borg Warner S372 turbo that I have sitting around, with the 406 I am in the process of building. Which brings me to fueling it...
It will be a blow through carb setup. Calculations call for an 850 carb n/a, but I don't know if that much cfm will be needed for a boosted application, any ideas there?
Any suggestions on fuel pump(s) Internal/external? single/dual?
Old Oct 21, 2012 | 01:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Feeding fuel to a 406 w/ S372 turbo...
If you did intank walbros, a single at carb pressure should support 600whp easily. Just need a -10 feed line i guess. Not a carb guy. Lol
Dual intanks are good to 1000 depending on pressures
Old Nov 23, 2012 | 01:04 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
Thanks for the reply. How exactly would you go about setting up dual intank pumps?
Old Nov 23, 2012 | 10:27 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I called Lonnies performance as he builds them for a variety of applications. I switched to 4th gen plastic tank. Basically Y them together. Bunch of fittings needed and then need a way to activate the second pump, usually either a wot switch or boost pressure switch aka hobbs
Old Nov 23, 2012 | 12:45 PM
GTAShief's Avatar
Car: 87 GTA/90 GTA
Engine: Blown 383/Stock 305
What kind of tank are you using?
Old Nov 25, 2012 | 06:34 PM
91FirebirdAlex's Avatar
Car: 1991 Pontiac Firebird
Engine: Carbed LQ4 6.0
Transmission: blew trans up....T56 on the way
Axle/Gears: 9 bolt 3:45's >:)
Id like info on this as well,
oh btw, the set up i'm currently trying to accomplish will be using a 750 holley dp. from what I have read and from talking to other locals, the magnafuel external pump is a great route ( quite pricey) but never the less I heard its a great pump. I'm looking into holley blacks as well. what horespower number are you trying to achieve?
Old Nov 25, 2012 | 11:18 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
yea, i went back and read your build thread after my last post. impressive work.
I kinda want to go the route of capping off the stock fuel lines and putting a feed and return fitting at the bottom of the tank. I'm not 100% on what I will do as of yet though.
Old Nov 25, 2012 | 11:21 PM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
Yea, I think i'm going to self mod my 750dp for blow-thru. as for the pump, i have my eyes on the aeromotive AEI-11202 from summit.
I don't really have a horsepower goal, but squeeking into 9's would be cool I suppose.
isaacim
Jun 12, 2015 07:08 PM
Genopsyde
Oct 21, 2012 01:58 PM
Gearstix
Jan 5, 2009 02:58 PM
Keoki_Firebird89
Mar 10, 2002 11:50 AM
