map sensor for supercharging
Old Nov 25, 2012 | 09:34 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
I'm running the Crane Hi-6s ignition on my '87 350 tpi. Going to be supercharged soon and gathering parts. Looking for a boost retard unit and also at least a 2-bar Map. The one for the Crane system is $90. can i use 12223861 in place of crane hi-6s map? This is a 3 bar GM unit from 3.8 turbo cars. Thanks,Chris
Old Nov 25, 2012 | 09:40 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: map sensor for supercharging
2bar map for an ECM or for an ignition box?
I'm using a GM 2-bar map with a megasquirt.
You shouldn't retard spark under boost.
-- Joe
Old Nov 25, 2012 | 09:44 PM
sparks454's Avatar
Car: 1987 GTA
The crane manual offers a TRC-2 module to retard timing with a 2-bar MAP for their ignition module. The TRC-2 retard module plugs into the ignition module as does the MAP. The timing retard is then called 'boost proportional' to prevent detonation..Sound right?
Old Nov 25, 2012 | 09:49 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah it's a BTM. Not the best idea.
Better off using a ECM with a 2-bar map to control fuel and timing under boost.
-- Joe
Old Nov 25, 2012 | 09:53 PM
sparks454's Avatar
Car: 1987 GTA
I've put a LOT of time and tuning in my 165 with 6e and would still like to use the MAF. I'm assuming that I can still utilize my current tuning and add the timing retard and MAP sensor to the procharger system when I get it and still be well off? i'd rather not swap the ecm at this stage before adding more engine mods...
Old Nov 25, 2012 | 09:55 PM
sparks454's Avatar
Car: 1987 GTA
I should post on the prom board, but what needs altered in my tables to accomodate the blower if I were to not use the boost controller and MAP?
Old Nov 25, 2012 | 09:57 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The stock MAF won't measure enough airflow to be useful with any type of boost. Tequilaboy patched the MAF code to work with a ford MAF sensor which works a bit better.
I think you're going to hit a wall where your fuel value is 255 way early on (both rpm and boost wise) and you then try to use the PE adder to add fuel, but it won't ever be right.
Sorry.
-- Joe
Old Nov 25, 2012 | 10:00 PM
sparks454's Avatar
Car: 1987 GTA
Yea..I was aware of the PE table corrections needed. Just wasn't in the frame of mind to change over to SD yet. She runs so good the way it is. Didn't want to mess with it if it wasn't broken..lol. I was in the process of doing the 3.5" MAF mod per another post I found and was going to change the MAF scalar to accomodate it..
Old Nov 25, 2012 | 10:15 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's going to need a complete re-tune anyway when you add the blower.
What blower are you adding?
-- Joe
Old Nov 25, 2012 | 10:16 PM
sparks454's Avatar
Car: 1987 GTA
Would like to stick a D1sc in there.
Old Nov 25, 2012 | 10:18 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah, that moves a stupid amount of air. You're going to need to think this over.
-- Joe
Old Nov 25, 2012 | 10:20 PM
sparks454's Avatar
Car: 1987 GTA
There are most likely going to be future engine upgrades as well. I would rather buy once..
Old Nov 25, 2012 | 10:22 PM
sparks454's Avatar
Car: 1987 GTA
I just hate getting into rewiring things for SD. Been reading this post and he says there are wire colors on his 165 ecm connectors that don't match the original pinouts,etc...https://www.thirdgen.org/forums/tpi/...-maf-sd-i.html
Old Nov 25, 2012 | 10:39 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The colors don't matter, the pin ID does.
The '165 ECM (specifically $6E) wasn't intended for the airflow you are planning. Either you need to switch to an ECM or code mask that is (like $12p which will work in your '165) or run a piggyback device. (injector multiplier, fmu, superfueler, etc)
-- Joe
Old Nov 25, 2012 | 10:40 PM
sparks454's Avatar
Car: 1987 GTA
I was planning on superfueler or fmu.. Maybe just go the SD route to eliminate having to use an FMU and MaF? Sounds like things would be a bit simpler.
Old Nov 26, 2012 | 08:05 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i've never had luck with the fmu on my speed density, code59 and tuning with a 3 bar map, no timing retard.
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
