turbo where ac unit is ...
Old Dec 4, 2012 | 06:51 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i'd like to get rid of the ac unit . i know they make a pulley but is there anyway to get rid of both the air pump an ac unit an still keep the serpentine belt ?
Old Dec 4, 2012 | 07:11 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: turbo where ac unit is ...
Yes. On my old build thread I threw up pictures showing how I modified the stock serpentine bracket (passenger side) to eliminate both the AC and SP mounting area without weakening the bracket itself (remember, there is tension, and if you remove too much material it will crack, so keep it strong). I then ran a rope around the system to accommodate the reversed water pump while bypassing the AC & SP, and got a new belt for it. Works like a charm...
Old Dec 4, 2012 | 10:34 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
how are you holding tension on the belt after that ?
Old Dec 4, 2012 | 10:51 AM
Still using the stock tensioner, but a lot of the passenger bracket has been cut, removed and smoothed down to both look factory and to make way for the turbo. My turbo compressor is positioned right where the AC used to reside...
Old Dec 4, 2012 | 10:55 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm gonna have to relook at that pic .
Old Dec 4, 2012 | 10:56 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
could you p[ost the pic on here ?
or give me link to the thread .
i'm gonna have to relook at that pic.
I pulled all of the pics from my build. I will post one for you in this thread when I get home later...
Old Dec 4, 2012 | 10:58 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
thanks
BumpaD82
Feb 26, 2016 02:57 PM
dbrochard
Jan 28, 2016 08:42 AM
New2Chevy
Sep 28, 2015 12:35 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Glowsock
Sep 5, 2015 07:48 PM
