thinking of getting n2o kit.
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I've never posted in this section before so forgive these rookie questions. I have a 385 stroker with forged internals. I was thinking getting a n2o kit, nothing to crazy. Would I need to adjust my computer tune and injector size to spray the engine? Does n2o damage the engine? I was thinking of 100-150 shot.
http://m.summitracing.com/parts/nos-05151nos/media
Car: 89 Formula 350
Car: 89 Formula 350
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 Formula 350
Car: 89 Formula 350
Car: 1989 Iroc Z L98
Re: thinking of getting n2o kit.
I don't know enough about EFI to help you much further than that, especially aftermarket stuff. I would recommend you look at Nitrous Express as well, NOS kits seem like they haven't changed much in the last 15 years.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If you want to run a plate kit, do a tpi based kit behind tb. Else buy an efi single nozzle wet kit and add onto it as you see fit.
Wont have to change the tune but need to pull some timing. Like said start with smaller shot and pull around 2 deg per 50 hp. I just threw in my 150 shot jets and pulled 6 deg via my ignition box which has nitrous control. Jetting was pig rich and timing was low. Ended up jettin fuel leaner until it was around 11.8-12.0 air fuel and added timing back in where it took only 2 deg less than my na tune. Went from 10.9's at 124 mph spraying high first gear, to 10.63 at 127-128 spraying off converter. Picked up 3 mph with jet and timing change but i think it may have been too aggressive as i found a plug with no ground strap.
My kit i added a wot switch on the throttlebody and ran that to a rpm window switch in my ignition box. Also wired it to the timing retard function. So nitrous only came on when car was at wot and above certain rpm and while that happened, it pulled timing to a preset value
Car: 89 Formula 350
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by TPI-Formula350-
I have a 385 stroker with forged internals. I was thinking getting a n2o kit, nothing to crazy. Would I need to adjust my computer tune and injector size to spray the engine? Does n2o damage the engine? I was thinking of 100-150 shot...
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
im gonna give you my
, i been doing the nitrous thing since the mid 90's both on my 1990 gta and my x275 drag car(500+hp of n20)
i suggest the nos 05151 plate system or any plate system that goes behind ur tb.
then you should get a msd digital timing retard box for ur msd, with your compresion you can get away with 93-94 octane .
with a 150hp jetting i would start -6* from your base timing n/a, ngk 5 or 6 should do your tune up it's going to be rich for sure.
start taking fuel out untill you have it cleaned up, then and only then!!! start adding timing.
do not tune with your o2/wide band on nitrous.....i will tell you why...o2 sensors many times are thrown all over the place with an adition n2o on the mix...there is many gases produced from the burn with nitrous wich will show a rich reading sometimes the other way around depending on 0/2 sensor!!!
only tune with ur plugs and i mean the 8 of them not just 1.... once ur happy with ur plugs, where ever ur o2 reading is...it's going to be just that a reading...don't get all hang up on it.
tips i suggest u should know:
_dont try to squeeze every hp out the tune as pump gas is not cosistant like race gas so lil bit on the safe side is better
_to fine tune ur fuel after fuel jet has been reached...use ur afpr to fine tune it in 1/8-1/4 lb incresments
_only add 1* at time
_watch mph on the 1/4 mile for ur timing the moment ur reach max mph on ur tune up thats going to be ur best timing
i think that should sum it a lil bit i can get into it deeper but for a start thats good..lol
this is only my opinion and many many years of playing with n20...my gta runed mid 11's on motor dd and after tunning on 150hp n20 jet i got 10.21, im going to try 200hp n20 jet hoping to get 9's hopefully..lol
, i been doing the nitrous thing since the mid 90's both on my 1990 gta and my x275 drag car(500+hp of n20)i suggest the nos 05151 plate system or any plate system that goes behind ur tb.
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
I never retarded timing until 150 shots. I thought it was 2 degrees every 50hp after 100hp. I ran 3 degrees retarded timing with a 180 shot on hyper pistons and 91 octane for a long time without problems. It was fine when I pulled it off the car
http://m.youtube.com/#/watch?v=FMEe7JqBgvg
Mickeyruder
Sep 2, 2015 02:45 PM
