3bar map sensor ...
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: 3bar map sensor ...
i hooked it up set the ebl per rbobs instructions an the idle jumps all over the place a ses like is on . then it just stalled out . put old one back in an it runs fine again .
what part number did you order ?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
However, I wouldn't say it's junk just yet. For starters, not all 2 bar maps are equal which is why most aftermarket ECM's have a map calibration table for voltgage vs kpa.
Are you going from a 1 bar to a 2/3 bar? What is the voltage of the sensor at key-on, but not while running?
-- Joe
Engine: l98 tpi
Axle/Gears: 2.77
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Its just a universal if i remember right. Let me see if i can find a part number
http://www.robietherobot.com/storm/mapsensor.htm
Edit. See link
Edit. See link
Car: 89 Iroc-z
Transmission: TH400
I use it with stock gm pigtail and works fine for my gm ecm. Its suppose to be a gm based sensor replacement.
Car: check
Engine: check
Transmission: check
3-bar MAP sensor:
(AC-Delco #213-1562) = 12223861 (formerly 16040749, AC-Delco #213-101)
At sea level, key-on, engine-off, the output voltage should be about 1.6 V, and report about 104 KPa. Use the WUD diagnostic display for this.
RBob.
RBob.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by freaky
i bought one off ebay an it's junk . where can i order a good 2or 3 bar map sensor ?
Engine: l98 tpi
Axle/Gears: 2.77
thanks guys for all the help . i'm gonna order a new one this weekend .an start m turbo install finally !
Engine: l98 tpi
Axle/Gears: 2.77
i know man . i done planned this thing to death . i have all the part finally now i just gotta find the time .lol my transmision is on it's last leg . it slipps under anykind of hard acceleration . i'm working two jobs trying to get a new tranny soon . it's all coming to getter tho
Are you sure? If you look at the weatherpack conn there are "slits" in the "tubes" for the pinouts. The 1 bar MAP has a different configuration from the 2 and 3 bar map ones. Check the corresponding tangs in this pic
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
A 1 bar plug/connector shouldn't fit a 2/3 bar map.
-- Joe
Engine: l98 tpi
Axle/Gears: 2.77
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I took the GM part number to o'reillys and they crossed it, and ordered a "BWD" brand sensor. Works great and seems to be better made than the ebay peice
PN: EC1678/BWD
PN: EC1678/BWD
Car: 89 Iroc-z
Transmission: TH400
Let me double check my pigtail source. I thought it was a gm based map pigtail and it does work with msd 3 bar no problem.
I dont remember exactly but i may have bought the gm 3 bar map pigtail from diyautotune. I know it was not a factory gm 1 bar pigtail, didnt mean for it to sound that way. Not sure if gm ever made a 3 bar map car? I guess so since there are part numbers. The pigtail did say gm 3 bar map sensor pigtail
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
At around 1,000 foot lbs of torque that thing was a rocket.
-- Joe
Car: check
Engine: check
Transmission: check
The 3-bar MAP sensor was used in the '89 Turbo trans Am (3rd gen Firebird
). Although, IIRC, may had the +5V and GND terminals reversed from the 3-bar MAP sensors made shortly thereafter & today.
I too either cut new slots in the connectors for the keys, or snap the keys off inside of the MAP connector. Many times the keys snap off clean with a little pressure from a pair of long nose pliers. It is best to only do the key-snap on the sensors that have the plastic insert. Pull the insert out to snap thems off.
RBob.
). Although, IIRC, may had the +5V and GND terminals reversed from the 3-bar MAP sensors made shortly thereafter & today.I too either cut new slots in the connectors for the keys, or snap the keys off inside of the MAP connector. Many times the keys snap off clean with a little pressure from a pair of long nose pliers. It is best to only do the key-snap on the sensors that have the plastic insert. Pull the insert out to snap thems off.
RBob.
Engine: l98 tpi
Axle/Gears: 2.77
i'm gonna order the one street lethal sugested . my fuel pump is taking a crap on me at the moment .i guess thats where i'll start first on ther turbo install .
Car: check
Engine: check
Transmission: check
yea i don't see me going over 15 psi...
